Sponsored by:
Sponsored by: CARiD
Anybody's Traction Control turning itself off?
Old Sep 30, 2008 | 09:43 PM
tomatoEVO's Avatar
for the past couple weeks, as soon as i turn on the car, ASC turns itself off and a yellow message pops up on the trip computer saying service required. and the little diagram of a car with the wheels turned to the right followed by the car swerving. before all this happened, i noticed when i turned on exits to the right, the car would slide abnormally and asc would then turn itself off.
this happen to anyone else? what could the problem be?
p.s. someone nicked my car bad in the parking lot the other day. paint completely gone in some places. this car has been nothing but a headache since i got it (if anyone remembers the intake spacer issue)
Old Sep 30, 2008 | 11:35 PM
UntouchableEvo's Avatar
With anything related to the vehicle's computer I'd say go to the dealership. I had the Check Engine light on and took it to the dealer ship they reset the comp and the issue was fixed.
Old Oct 1, 2008 | 03:50 AM
DVDee's Avatar
Get this checked out at the dealer. It's a problem with the S-AWC it's hard to say which one of the specific systems though.
Old Oct 1, 2008 | 04:04 AM
gotrnet's Avatar
check that you don't have a brake light out. that will kick off the asc system. and be sure to use stock bulbs. the car keeps track of how much load is on the wires to the brake lights. if you replace with led's or something then the load is wrong and it will kick off the asc. that will kick off the asc system.
Old Oct 1, 2008 | 07:08 AM
tomatoEVO's Avatar
ah, i see. thanks guys
Old Oct 1, 2008 | 09:15 AM
Asta4125's Avatar
If these are all the problems you have with you X, you should feel good. A spacer on an intake can be anoying to figure out..but not a biggie. And if you take it to the dealer..and they fix the warning light...then you lucked out. Being unlucky is throwing a bearing in the motor or trans.
Old Oct 1, 2008 | 02:07 PM
macPSU's Avatar
When I push it too far on a turn and my back end starts to slide out, the orange traction symbol lights up on my trip computer (the car w/ the swirves under it). Is this normal for when the car starts to lose traction or is that the ASC actually turning off?
Old Oct 1, 2008 | 02:20 PM
Papi4baby's Avatar
I know other cars will flash the same simbol when the VSC system starts to do its job, and it will beep just to let you know.
Old Oct 1, 2008 | 02:33 PM
EvoXstylin's Avatar
This is new to me.. Just take it and have the dealer check it out.
Old Oct 2, 2008 | 06:33 AM
tomatoEVO's Avatar
it's definitely not normal to lose asc everytime I turn it on
Old Oct 2, 2008 | 07:21 AM
heavens turbo's Avatar
if the light is on on the dash, (car with squiggles), that means you turned it off. when you lose control and it flashes, that means it is working. if a message says service traction control, you definately have a problem and i would take it in. the computer stores codes even if the ses light is not on.
Old Oct 2, 2008 | 07:15 PM
UFO's Avatar
UFO
That's just the ASC letting you know that it cares for you and that it's there for you. In other words: it's letting you know it's doing something to prevent you crashing into a wall in a fiery ball of rubber, aluminium and plastic.
Old Oct 2, 2008 | 07:25 PM
TTP Engineering's Avatar
It might be a wheel speed sensor.
Old Oct 3, 2008 | 05:06 AM
Evo_gg's Avatar
that is is odd, i have a similar issue, mine will start up and flash the Periodic inspection light with the wrench, however it will not allow me to disable the ASC... I hope you don't have to go to the dealer every damn time to be able to deactivate your ASC.....agggghhh!
Old Oct 3, 2008 | 11:22 AM
hel_if_ino's Avatar
When I overboost it will trip this same light and turn the asc off... try checking your boost lines.
