Best quarter mile...
Old Sep 30, 2008, 11:44 PM
UntouchableEvo's Avatar
Thumbs up Best quarter mile...
Alright, for the best time in quarter mile on my GSR Evo X, at what RPM range should each shift happen? I thought at about 5500 RPM from 1-3 and then 3-5 at about 7000 RPM?
Suggestions very welcome...
Old Oct 1, 2008, 11:36 AM
Joe's Evo X's Avatar
It depends on your power curve. I took mine all the way to 7,800 rpms. For stock i would red line it to 7,000. And as far as 5 th gear you probley wont hit that in the quator mile. I barly hit it and i sitting on almost 400 awhp and trapping out at 116mph.
Old Oct 1, 2008, 02:00 PM
Alright sounds good, and yeah my Evo is stock. I'll give it a go going to 7,000 RPM and see where that gets me.
Appreciate the feedback.
Old Oct 1, 2008, 02:02 PM
steinvb12's Avatar
For stock, I actually found shifting at 6,500 provided a higher mph. The torque curve on a stock car drops off quick once the rpm's go up.
So I would try anything between 6,500 and 7,000. Try both and see what works for you. Maybe it's a combo or inbetween at 6,800 which yields the best results.
However, 5,500 I would say is too low. No reason to shift that low.
One more thing, never shift into 5th. Just ride 4th out no matter what rpm!
Old Oct 1, 2008, 02:30 PM
That is the big thing steinvb12, I didn't ride out 4th long enough. I'll give 6,500 and 7,000 a go.
Also if it says that the max torque is at 4,000 rpm; shouldn't the shifting be done so the next gear falls in the 4,000 rpm range? I don't really understand the whole: Max Torque: 4000 RPM Max - Horsepower 6500 RPM on the stock Evo X Spec Sheet.
Old Oct 1, 2008, 02:31 PM
Also (sorry about all the questions...again) if modding was to be done, does that void the warranty?
And would taking off the ASC make any difference?
Old Oct 1, 2008, 04:28 PM
def1's Avatar
torque always falls off sooner than hp. You need to shift at the mazimum horsepower and not maximum torque. Shift at 7000 so your in a better power curve when u get in the next gear. and yea dont get out of 4th
Old Oct 1, 2008, 05:34 PM
xtremeboost's Avatar
We've been shifting at 7k but we sure look forward to 8,200 shifts Coming this weekend
Old Oct 1, 2008, 05:42 PM
def1's Avatar
what kinda times are you expecting?
Old Oct 2, 2008, 12:21 AM
Realistically I'd say 14.5 seconds would be a fair start.
I might test it out this weekend depending on weather.
Old Oct 2, 2008, 12:31 AM
SiC
SiC's Avatar
Yes, be sure to turn off ASC (hold the button down for like 5 seconds). It dampens the throttle and makes it so you can not launch. ASC also applies the brakes to your wheel if you break traction.
Old Oct 2, 2008, 03:38 AM
Deannn's Avatar
i thought X's do stock 13.5 /13.7's s
Old Oct 2, 2008, 06:08 AM
Hiboost's Avatar
If you have excessive wheelspin problems off the line then just the single touch of the ASC button "may" yield better short times which turns off the power cut (almost always evil) but leaves on the brake assist (can be good sometimes). You can test both and see what works best, if you can turn it all off and modulate the power well for limited wheelspin that will yield the best times.
Old Oct 2, 2008, 02:15 PM
Deannn you are correct about those times, but I am shooting for realistic timing, I know I do not have the shifting patterns for the Evolution X down pat so I figured a more reasonable time and then improve from there.
Also today I tried a clean start on a recently paved new road in the morning, I pressed the ASC button and had a fairly good start, however I will try completely turning off the ASC (holding for 5 sec.) and giving that a go.
Old Oct 2, 2008, 02:17 PM
steinvb12's Avatar
The BEST drivers can manage those times, yes. However, most of us are unable to reach those times.
If you are new to drag racing, expect a 14.2-14.5. If you have some experience, then 14.0. If you are a good driver, 13.7-13.8. If you are a really good driver with a bunch of experience, then a 13.5 is possible.
Set your goal realistically....people forget to realize, alot to drag racing is the driver!! And I'll be the first to admit, I am not the best. So I just adjust my expectations realistically. And as I get better, I can expect more.
Quick Reply: Best quarter mile...
