Sponsored by:
Sponsored by: CARiD
Idle Problem
Old Nov 23, 2008 | 11:08 PM
  #31
HardRideCafe's Avatar
Have any of you having idle problems gone to the dealer to see if they can help?
Old Nov 23, 2008 | 11:14 PM
  #32
ch3njiawei's Avatar
Registered User
most dealers will only help if you have a the CEL on unless you have a good dealer, for my case, I had to wait until the CEL popped out to get my reflash
Old Nov 23, 2008 | 11:23 PM
  #33
Karam's Avatar
Originally Posted by KPerez
As an addendum to my earlier post, changing the intake from OEM to an aftermarket piece eliminates the air insulation of the relatively closed OEM "box" thereby allowing the variable heat within the engine bay to influence the MAF. Bottom line: If you cannot live with the idle fluctuations of most aftermarket intakes [some e.g., ARC do offer air insullation by their design], then go back to the OEM "box"; otherwise accept it with the understanding of its cause.
Later, Ken
AMS intake&single exhaust
Iveytune (322 all around)
Robispec K&W
Its strange, but after my car got tuned, the idling stopped hunting! it was really bad before the tune, it would hunt between 1000-1500rpm especially on hot days at the lights!
Old Nov 24, 2008 | 05:31 AM
  #34
gunzo's Avatar
Simple reason .. you reset the ECU when you flash and allow the @#$)#$*T% Ethrottle to relearn itself ..
When the hunts alot (not your normal radiator fan ON OFF type), your best bet is to switch off and start up the car again with aircon off and let it settle down 1st ..
If it keeps coming back, just reset the ECU and start up with the aircon OFF to ensure the calibration cycle is correct ..
Old Dec 3, 2008 | 08:27 AM
  #35
Originally Posted by fmax420
My car does this and it is bone stock.......
Go to the dealer and see if your car has the most recent reflash.
