Sponsored by:
Sponsored by: CARiD
is it safe to put jack stand on rear sub frame rail?
Old Nov 5, 2008 | 07:39 PM
xXEVOloverXx's Avatar
hi guys i wanna jack up my car and is it safe to put jack stand here,anyone have done that be4? thanks
Old Nov 5, 2008 | 07:42 PM
DarksideEng's Avatar
Why not put it on the frame rail on the outside?
Old Nov 5, 2008 | 07:49 PM
cause i don;t have floor jack
Old Nov 5, 2008 | 07:56 PM
meat_EVO's Avatar
what are you using then? and yes, you can put it in either spot.
Old Nov 5, 2008 | 07:57 PM
i use that oem jack from the car
Old Nov 6, 2008 | 11:18 AM
RicerX1's Avatar
nope i jacked my car up from there and it crumpled a bit.
Old Nov 6, 2008 | 11:26 AM
goofygrin's Avatar
I wouldn't jack there. The OEM jack should go on the part right by notch at the end of the arrow (not the pointer).
Old Nov 6, 2008 | 11:30 AM
Protostar1's Avatar
There is a jumble of parts and components down there, but I would go for a suspension mount point if you cant use the OEM jack point. And I can never remember until I am under the car... but I am pretty sure I use that chassis rail for my jack stands as well and have had no adverse effects. I also have polyurethane jack covers which probably helps, but if you gotta use the rail dont place the stand near the bubbled part of the rail (ie left of the arrow) go towards the creased sections. Good luck!
Old Nov 6, 2008 | 11:49 AM
krnkimchi702's Avatar
you own a sub 40k car and dont have a floor jack...go buy some
Old Nov 6, 2008 | 12:18 PM
08EvoXGSR's Avatar
OEM jack is designed to use the pinch weld by the rocker-if you buy a low lift jack (there is a nice set up on amazon-its the blue one with jack stands for like $170) you can jack from the point you are indicating and you will be fine-this is where most shops use a 4 pt to raise the car from-but the pressure is spread out more-the OEM jack is a little small, and you may wrinkle a little. Winter rims going on?
xXEVOloverXx
May 30, 2009 09:06 PM
xXEVOloverXx
Dec 12, 2008 05:12 AM
xXEVOloverXx
Dec 3, 2008 03:41 PM
xXEVOloverXx
Jul 2, 2008 12:44 AM
bbuevo
Feb 8, 2006 03:44 PM
