Sponsored by:
Sponsored by: CARiD
What should i do
Old Nov 9, 2008 | 07:42 AM
jato3.3's Avatar
Unhappy What should i do
So i just got a new clutch installed from dealer (ACT) and was told that my flywheel was burnt due to my bad driving habbits with stock clutch lasting only 5K miles. Should i expect same again or just leave the evo and look for an automatic car lol. BTW this was my 2nd manual car
Old Nov 9, 2008 | 07:57 AM
scottatyamaha's Avatar
What are your bad driving habits? Two step launches at every red light?
Old Nov 9, 2008 | 08:01 AM
gizmotoy's Avatar
I can't say I've ever heard of a stock organic clutch burning a flywheel before. Upgraded aftermarket clutches, sure, but the stock clutch on the X is even widely-known as being weak.
It's one of the three: (1) Bedded improperly, (2) you do have a habit of riding it and causing increased wear (3) it was simply defective from the factory and failed through no fault of your own.
I imagine you're the only one that can truly know which of the 3 it was the caused the premature failure.
Old Nov 9, 2008 | 08:11 AM
Robevo RS's Avatar
trade it in for an MR
Old Nov 9, 2008 | 01:24 PM
Papi4baby's Avatar
LOL, if you burnt your clutch @ 5k, might as well. Then again maybe you did learn after burning up one clutch.
Old Nov 9, 2008 | 01:33 PM
infinite_666's Avatar
just learn to drive it better, we all learn from experience. if its a bad habit, then change your habit and that is all. maybe explain to the forum what you do , and maybe we can help you.
Old Nov 9, 2008 | 01:46 PM
btownsoccer22's Avatar
yea just tell us how you drive and what you do and we can give you pinters
Old Nov 9, 2008 | 07:42 PM
trexxx8739's Avatar
how much did it cost you?
Old Nov 12, 2008 | 06:29 AM
jato3.3's Avatar
Thanks. I thaught i drove ok never launched ok may be 2 times . Its a DD no track or abuse. But what confuses me is why they changed the clutch and tapped me with 2K and just re-surface the flywheel? Shouldn't they have rather changed the flywheel to a better one?wouldn't this be same again.
I am keeping this car because i like it even more than a GTR lol i know ppl might think i am crazy but what can you do its an EVO
Old Nov 12, 2008 | 07:50 AM
EvoDom's Avatar
no the flywheels normaly jsut get re-surfaced unless you really scored the surface up. when i did my clutch i just bought a new fly wheel since my stocker was pretty beat up. your flywheel was probably in good condition and just needed a resurfacing, but you clutch plate was shot. you should be ok just dont ride the clutch.
Old Nov 12, 2008 | 08:05 AM
Ph3n1x's Avatar
2000 for the job?
You got Cornholed
Old Nov 12, 2008 | 11:07 AM
honeybadger's Avatar
Does it confuse you that dealers will try to exploit you as much as they can and rack up the $$$?
Old Nov 12, 2008 | 06:24 PM
Dr. Ev0L's Avatar
actually that goes with most shops, not just dealers. i see more people getting raped at midus then the dealers. dealers know the cars inside and out (well they should). thats why you take your car there.
Old Nov 12, 2008 | 06:46 PM
sl0ev0's Avatar
the auto business is shady. they probably f'd you. just learn from your mistakes.
