Sponsored by:
Sponsored by: CARiD
Wingless plugs
Old Nov 20, 2008 | 07:58 PM
MightyPhantom's Avatar
I just went to Kragen and got some Blackout Tape. Just cut out 6 dime size circles, and viola!
Old Nov 20, 2008 | 09:15 PM
EVIL_EVO_VIII's Avatar
all i wana know is what size plugs for all the holes so i dont have to be going back and forth to the store
Old Nov 21, 2008 | 05:19 AM
ibognar's Avatar
They're about 25 cents each. Just buy a whole bunch and throw the rest away.
Still can't get that rectangular plastic piece out of the middle hole. Anyone?
Old Nov 21, 2008 | 11:46 AM
what part is that?
Old Nov 21, 2008 | 04:30 PM
ibognar's Avatar
They're called plugs and they're in the bolt and screw section.
Got an estimate today to fill (weld) the holes and paint: $700 for the trunk only, $1050 for trunk and fenders (for better match because of the metallic paint.)
"Ghetto" doesn't seem so bad now.
Old Feb 1, 2009 | 06:56 AM
bigben's Avatar
ya beat me to it, I went to a local vinyl decal shop and they gave me some scrap. It didn't cost me a thing and keeps the water out if it rains. cheap, yet affective. I used quarter sized hole cut-outs (25 cents, not 1/4).
Old Feb 1, 2009 | 09:55 AM
Farmerbob's Avatar
If anyone has pictures of their Evo X without the rear wing, can you post em up. Most interested in say 15-50 feet away. In my neck of the woods, it's sort of like a red flag for the CHP's, so I want to see what they see from the highway view. Thanks.
Old Feb 1, 2009 | 02:52 PM
Methodical4u's Avatar
I have an idea.. which might be stupid.. but what about using just a silicone or something, flattening it out even with the trunk and then putting a little paint on it? Will paint even stick to silicone though?
Old Feb 1, 2009 | 05:11 PM
boostin20's Avatar
I just pulled my wing off my car. It was all good until I looked at the holes from the two bolts under the covers on top of the lid. There are f'ing nuts welded to the underside of the lid where these bolt into. I didn't have any grommets at the shop under 6mm which wouldn't fit unless I ground the welds and removed the nuts. What are you all doing for this? I'm thinking about either finding a wingless trunk or visiting the body shop.
Old Feb 1, 2009 | 05:46 PM
Bighec's Avatar
Sounds like the dealer welded the retaining nuts to your trunk. What size spoiler did you have, SSS or Lancer?
Old Feb 1, 2009 | 05:55 PM
boostin20's Avatar
Originally Posted by bighec
sounds like the dealer welded the retaining nuts to your trunk. What size spoiler did you have, sss or lancer?
sss, and the nuts are welded to the underside of the lid, between the outer and inner metal skins. It looks pretty factory to me, and I can't get to them at all without cutting the inner metal skin.
Old Feb 1, 2009 | 06:42 PM
Bighec's Avatar
I can't speak for the SSS wing because i have the cheap-o spoiler, and mine were just bolted on the under side, not welded.
Maybe that's how it comes from the factory, and the one's that are not welded are added at the port, or dealer???
Old Feb 1, 2009 | 07:05 PM
boostin20's Avatar
Do you not have one bolt on each side of the wing with bolt heads on outside of the trunk, with the bolt going into the trunk lid?
Edit: I would take pics, but it's dark and freakin freezing.
Old Feb 1, 2009 | 09:02 PM
Bighec's Avatar
Yea, I have one stud on each side with a retaining nut, and one bolt on each side, along with the stud that clips into the trunk lid. But my retaining nuts are not welded to the trunk lid.
Old Feb 2, 2009 | 12:02 PM
lowkey's Avatar
Registered User
For a temporary solution, the quickest fix is to just buy electrical tape of the same color as the car. The best long term solution is to have a body shop fill in the holes and re-spray the area then clear coat the whole trunk. Because the holes are not in a straight line and the plastic plugs are not complete flat it does not look good. I have not tried the vinyl option, it might work too.
