Sponsored by:
Sponsored by: CARiD
Starter Issues?
Old Dec 10, 2008 | 04:58 AM
KPerez's Avatar
Originally Posted by smoothevo
My battery was 100% dead as a door nail. It was so dead that my Commander (hemi) couldn't jump it. It was so dead that I couldn't unlock the damn doors with even with the truck trying to jump it.
Yes it was pulled and tested and it was shot ( 250 miles ). I was told there is a problem with the battery and a lot of them are coming back which is why there is a wait. On a side note dealer called and got my new batter installed today
Thanks Smoothy for info. Let us know how new battery starts; obviously it will be better than a dead one but interested in whether it really starts up on first try/turn. Also, did they install another OEM battery or a different one. If the latter, what is the brand?
Later, Ken
Old Dec 10, 2008 | 05:08 AM
flagg77's Avatar
This happened to me for the first time last night. It's been "slow" staring since day 1 but yesterday was just weird. It was literally 15 F in the morning and the car started fine. Then in the evening it was 50ish (massachusetts for you) and
- i cranked it for about 5-6 seconds it didnt start
- tried again for about 5 seconds, same thing
- tried again and pumped the gas a pedal a bit and it fired right up
I think its something other than the battery? Or perhaps at least in my case.
Old Dec 10, 2008 | 05:38 AM
dcgsr's Avatar
Starter problems probably not due to cold weather....
I had the starter problem again yesterday, we had a warm-front and the temps were 55. So as many others have pointed out, the problem happens in cold and warm weather...so its probably not due to cold weather....
I did pull my battery cable off while doing some work a couple weeks ago, and did not do the idle relearn procedure I've been reading about....I don't know if that's caused my starter issues or not. My car idles smoothly, so I never went through the hassle to relearn. The starter problem is not consistent so it'd be hard to point to that as the cause. Just thinking out loud...
https://www.evolutionm.net/forums/sh...d.php?t=383529
I'm glad to hear I'm not the only Evo X owner with the problem....hopefully we'll reach a consensus and find the cause...
Old Dec 10, 2008 | 10:39 AM
smoothevo's Avatar
Later, Ken
Installed another OEM battery and it cranks up really fast, 1-2 seconds max. I had a cheap battery from Walmart in the car while I was waiting for the new battery. It had the exact problems others are mention as far as taking a while to crank up and start.
If it's your starter when you bang on it with a hammer or heavy object it should start right up next time you crank it.
Old Dec 10, 2008 | 12:21 PM
KPerez's Avatar
I am confused with your last sentence. Are you suggesting a poor connection?
Later, Ken
Old Dec 10, 2008 | 01:37 PM
smoothevo's Avatar
Later, Ken
No, if the starter is going bad you will have a clicking noise and it won't start. One of the ways you can tell your starter is going bad is by hitting it with a hammer or heavy object when it won't start. If it starts after you have hit it a few times your starter is going bad.
If you are referring to the "cheap" battery I installed temporally that wouldn't start up right away it's because it didn't have enough juice.
Old Dec 10, 2008 | 02:20 PM
zTargeTz's Avatar
stock ECU flash is too rich.
welcome to starting a rich car in the cold.
