Sponsored by:
Sponsored by: CARiD
Check engine light
Old Jan 26, 2009 | 12:44 PM
S2K2EVOXGSR's Avatar
Check engine light
anyone got a link to look up codes or can someone hook me up?
P1235
Old Jan 26, 2009 | 01:02 PM
SpaceMonkeyAndy's Avatar
Originally Posted by Noize
I got P1235 codes, overboost from a MBC. I added EcuTeK and ECU boost control and it resolved the issue.
https://www.evolutionm.net/forums/ev...135-codes.html
EDIT: Your sig doesn't list a MBC or any modification of the wastegate, so you might have a failing MAF sensor.
https://www.evolutionm.net/forums/ev...5-p0135-2.html
Old Jan 26, 2009 | 07:38 PM
Red Dragon's Avatar
Reset the ecu, to see if it comes back. If it does then you have a faulty maf, if it doesnt then i dont know. I had that code come on once before.
Old Feb 9, 2009 | 01:17 PM
nawgee's Avatar
how do you reset ECU....is that the same as pulling the negative off the battery for 15 min?
Old Feb 9, 2009 | 06:46 PM
laksman91's Avatar
yes, i believe so.
Ckeesee12
Apr 6, 2016 04:16 PM
Jamessvt2004
AEM EMS
26
Jul 5, 2012 10:12 PM
Talonmotosports
10
Jan 7, 2007 11:26 PM
yesevo
Dec 18, 2006 07:21 AM
