Am I driving weird?
^^^ Even if you "time it perfect" you're still subjecting the synchronizers to excessive wear and tear. There's no good reason not to use your clutch, unless you're driving an old 90s crank-walk-o-rama 46G3 car
Agreed. Your synchros are designed to match the input shaft speed when the clutch is not engaged--the engine has a lot more inertia that the synchros must be forced to overcome if you do it. Even when you become skilled shifting without the clutch, you can feel the stress you put on your transmission.
I find myself modulating the clutch with my heel on the ground and pivoting my ankle only from a dead stop. When I am rolling, I float my entire foot and press using the whole foot. I get to the bite faster and never accidentally pop it. I wear a size 11 shoe and it just feels like the bite is a hit or miss using my entire leg. I know it varies from car to car and the clutch. Asap I feel it bite i begin to slowly lift up my entire leg including the resting heel. I find this method perfect for me because it's as if the car is biting asap I can't pivot my ankle any higher.
Sorry to revive an old thread, but just thought I'd pitch in what worked for me.
Maybe some newer members can comment on their styles?
BTW, what size shoe do you guys wear? I always have to lift off the floor to push the clutch down and release.
Shifting
I have my foot off the ground while depressing the clutch, but plant my heel while letting the clutch back out. For me, this lets me have a little better control over the movement of the pedal when releasing, for a nice clean shift (especially when the car is cold).
I used to semi-float my foot when shifting a '90 Toyota Pickup, went to a Supra and killed that habit. I would rest my heel when not shifting, but would float when shifting. Same with the VR-4, it's nearly impossible to use the clutch without floating because it's so stiff. I've been test driving a few Evo X's, and the Evo X has such a light clutch and a less "sporty" seating position, so I might go back to rolling on my heel, but I kind of doubt it now that I'm in the habit of floating.
ridenrunwv
Oct 3, 2015 07:54 AM
