Sponsored by:
Sponsored by: CARiD
What can I replace the spare tire with?
Old Feb 15, 2009 | 11:39 PM
jackygor's Avatar
This might be a stupid question, but can I replace them with a inflation kit or something? I have 19 inch rim on my car, if I were to use the spare tire, wouldn't it screw up my diffs? I am hoping to lose some weight, that is all
Old Feb 15, 2009 | 11:52 PM
JoeyM3's Avatar
insurance that covers towing lol. . . .
Old Feb 16, 2009 | 12:51 AM
chueu's Avatar
Mine doesnt come with a spare tire but an inflation kit. I would think thats possible..
Not sure about the diff's though
Old Feb 16, 2009 | 01:24 AM
Smike's Avatar
Foam block, nothing, air pump...towing insurance.
Correct, running that spare now will cause issues.
Old Feb 16, 2009 | 05:19 AM
DarwinX's Avatar
In my old mach 1 to save weight when I went to the strip, I ran a styrofoam block that fit in the wheel wheel for the spare, and I carved out a section in it for a can of fix-a-flat.
Old Feb 16, 2009 | 09:26 AM
krnkimchi702's Avatar
if weight was your concern, why did you go with a 19 inch rims?
Old Feb 16, 2009 | 09:27 AM
Hatemy7's Avatar
lose weight by putting some 17's lol
Old Feb 16, 2009 | 09:39 AM
GNR's Avatar
GNR
I thought the lowest was 18 on the evo x... maybe next time run "RUNFLAT"
Old Feb 16, 2009 | 10:58 AM
jackygor's Avatar
It wasn't my biggest concern, I read that in other countries, the evo came with inflation kits instead of a spare tire. Since I have 19 on my car, I have no use for my spare tire anyways, if I bought it up, it will most likely blow a differential.
Old Feb 16, 2009 | 12:01 PM
bradnr's Avatar
I don't think it will blow the differentials. You see cars with donut spares all the time. I had a 4x4 with a smaller spare the worked for a short while without blowing the differential. Of course, those were all two wheel drive situations, but I still think the car will be fine as long as you aren't racing.
Old Feb 16, 2009 | 12:18 PM
Mad_SB's Avatar
Did you not keep the same rolling diameter when you picked up the 19's and tires???? If not your speedo is off now and your gearing will be affected as well. If the rolling diameter is the same no need to worry about using the stock spare with the 19's
Old Feb 16, 2009 | 12:49 PM
Ltdanish07's Avatar
+1 on fix-a-flat
Sheasta
Nov 3, 2015 03:04 PM
R Lar
Dec 20, 2012 08:23 PM
johnnycage
Oct 3, 2012 03:57 AM
xdmitrix
Jan 1, 2010 01:38 PM
35rEvo
Apr 9, 2009 12:54 PM
