Sponsored by:
Sponsored by: CARiD
Idle issue and die
Old Mar 10, 2009 | 04:47 PM
Excalibur's Avatar
Question Idle issue and die
Ok, I have a 2008 Evo X GSR that I bought around 2 weeks ago. Today when I started the car, I held the clutch in and was doing something with my phone and I noticed the idle was dropping from the 750rpm mark to under 500rpm and then back up and then it went back down and died. I started it back up and it did it again. The third time I started it, I blipped the throttle a little and it never did it again. I have 800 miles on the car. No mods. Still breaking it in. No CEL. Nothing else to note. Any ideas?
Old Mar 10, 2009 | 05:11 PM
janvin21's Avatar
do you do your reflash?
Old Mar 10, 2009 | 05:13 PM
Excalibur's Avatar
No reflash. TSB or aftermarket. Either way nothing.
Old Mar 10, 2009 | 05:14 PM
jackygor's Avatar
so is your car completely stock ?
janvin21's Avatar
go to the dealer and have them reflash your ECU or have a tune. that will take care of your problem...
Old Mar 10, 2009 | 05:22 PM
Excalibur's Avatar
What reflash? Recall or something?
Yes, completely stock.
Old Mar 10, 2009 | 07:20 PM
sweetapple4u's Avatar
Before you go for the ECU reflash, why not try this. It works for me...
Go buy a HKS drop-in Hybrid filter.. and it will improve your idling.. better airflow into your air intake.
Old Mar 10, 2009 | 08:38 PM
mangoes's Avatar
Mitsubishi released two reflashes for the X. To check if the dealer already flashed your car, pop your hood and look on the top left. There should be a white sticker there that says the date it was flashed. If you don't have that then, take it to the dealer and request for the reflash. It should be free.
I just talked to a buddy yesterday and he said before the reflash, his car would stall out and die also.
Old Mar 10, 2009 | 09:34 PM
janvin21's Avatar
just tell them that you need a latest reflash on your vehicle cause your RPM bounce up and down and die also, they know what to do.
Old Mar 10, 2009 | 09:38 PM
stikllr13's Avatar
^^^ Yea there are lots of threads about the idle issue. If the reflash doesn't help you then get a tune and that will.
Old Mar 11, 2009 | 06:31 AM
TK-EvoX's Avatar
As mentioned - get the reflash. The dealership should know. Why it didnt come with the reflash already is the question.. but anyways you will feel the difference immediately.
Old Mar 12, 2009 | 02:14 AM
JDMSecrets's Avatar
Reflash is garbage, it only is a partial fix just save your self the trouble and get a tune. Had my X reflashed and it only helped alittle but here and there it still dies at start up.
