Sponsored by:
Sponsored by: CARiD
Anyone else ditched the plastic protector panel under the car?
Old Mar 11, 2009 | 10:42 PM
jackygor's Avatar
Everything on the Evo is functional, remove parts at your own risk
Old Mar 11, 2009 | 10:51 PM
evolution253's Avatar
Originally Posted by jackygor
everything on the evo is functional, remove parts at your own risk
+1
Old Mar 12, 2009 | 03:11 AM
otbEVO's Avatar
Yeah, I would have figured with all of the built in air channels it would have been obvious that the undertray is functional, but apparently not...
Old Mar 12, 2009 | 05:02 AM
aftershock141's Avatar
I'll be leaving mine on.
Old Mar 12, 2009 | 06:46 AM
gunzo's Avatar
everything except the big elephant ear rearview mirrors
Oh yes .. and the metal vents under the bonnet too .. they are designed to be removed easily on track ..
Old Mar 12, 2009 | 03:53 PM
Chebosto's Avatar
not realy quite sure what the lift coefficient of the evo was, but on the Z it was near Zero,
that was due to the front chin under spoiler, stock undertray, and rear diffuser disguised as the stock exhaust canister.
the front undertray allows for full channeling of the air through the radiator and allows for proper heat extraction, also, it helps protect the belts and engine from foreign objects bouncing up into the engine bay.
if anything i would replace it with an entire flat sheet that extends past the front bumper (aka splitter) or a chaneled front diffuser to improve airflow (make it smoother) such that near the rear of the car the wanna-be stock diffuser works...
a really good book to read on aerodynamics and cars from Joseph Katz
http://www.amazon.com/Race-Car-Aerod...6898367&sr=8-1
it will tell you the benefits of having a smooth underside.
Old Mar 12, 2009 | 04:07 PM
LVSBB6's Avatar
+2
Originally Posted by noize
the undertray?
Leave it on, all you ********!
it helps reduce drag at speed substantially. Say it with me, aerodynamics.
It also protects the underside of your engine, ic, etc. From the elements.
Old Mar 12, 2009 | 04:28 PM
scottatyamaha's Avatar
It also directs air to the front brakes.
Old Mar 12, 2009 | 05:07 PM
tephra's Avatar
take it off if you like a dirty engine bay, reduced fuel economy, slower track speeds and more noise
otherwise leave it on!
Old Mar 12, 2009 | 05:17 PM
ChEvo8's Avatar
I agree with Noize , jackygor, and tephra
i say keep it on.
Old Mar 12, 2009 | 05:25 PM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Ehhh....I was thinking about replacing mine with the ralliart aluminium one.
Old Mar 12, 2009 | 10:26 PM
EndlessRed's Avatar
are there any other aftermarket options available?
Old Mar 13, 2009 | 01:41 AM
Kisada's Avatar
made by japanese company Carbing
http://www.bulletproofautomotive.com...il.php?ID=6815
Old Mar 13, 2009 | 10:56 AM
angelus1's Avatar
the thing actually channels air to the transfer case and more, there is a tread in a japanese web where it shows everything it does from aero and cooling. took mine off for an experiment and at 90 or so in a straight the front felt shaky, then with it installed it felt a whole lot smoother, plus my engine stays cleaner. to each his own.
Old Mar 13, 2009 | 11:32 AM
spdracerut's Avatar
Exactly.
1. Reduces front lift and drag
2. Directs air to the transfer case
3. Directs air to the front brakes
4. Improves cooling (radiator and oil cooler) by controller airflow around said components
If you want to change the oil, there are only two panels out of the whole thing that need to be taken off, and they use proper screws instead of the plastic crap.
