Sponsored by:
Sponsored by: CARiD
Code Puller?
Old May 31, 2009 | 09:56 AM
Silver06evo9mr's Avatar
Code Puller?
Just installed the o2 downpipe and testpipe from UR. It has the CEL fouler already built in but i threw a code anyway. I have no clue why tho? It could be the o2 sensor or im thinking im overboosting now cuz of the new parts. Only mods are these 2 new parts and a base flash. NO catback installed yet cuz its on backorder.
SO I Need a code pulled. Yes i know i can go to autozone or w.e.
My question is... Is it the same as the one in the VIII and IX's right in the OBD II port or is the newer one needed cuz its a new car. Excuse the ignorance, but my shop needs to know cuz they havnt seen a X yet and they need to know before i drive all the way there tomorrow for no reason.
Thanks.
Old May 31, 2009 | 10:59 AM
Deepseadiver's Avatar
OBD II port, same code reader as the VIII and IX.
Old May 31, 2009 | 06:31 PM
gizmotoy's Avatar
I didn't think the VIII and IX had a CAN bus. You need a code reader that supports the CAN protocol, so one that worked on an VIII and IX won't necessarily work on the X. The protocol is used in a number of cars now, so your shop should have a puller that supports it.
Old May 31, 2009 | 09:50 PM
intravino's Avatar
Carplugs
I've been using the obd2 CAN compatible scanner since 2 years:
OBDii scan tool
Works great, you just need a computer.
Old May 31, 2009 | 11:10 PM
Boostd4's Avatar
I picked up an OBDII scanner from Kragen for $100, mine is compatible with CAN cars.
Old Jun 1, 2009 | 02:46 AM
thanks guys
Old Jun 1, 2009 | 08:21 AM
code was o2 sensor suprise suprise. resetting battery now. so hopefully that keeps it away concidering i have the CEL fix on the testpipe.
Old Jun 1, 2009 | 06:28 PM
Grendelrt's Avatar
I bought this one, works perfectly. Scans and clears.
http://www.harborfreight.com/cpi/cta...emnumber=94169
Old Jun 1, 2009 | 07:53 PM
gizmotoy's Avatar
Same here. There's a 20% off coupon floating around too.
Old Jun 2, 2009 | 08:01 AM
Webman's Avatar
I bought a little cheapie off of ebay, but it absolutely will not work on the EvoX. Works great on every other car I've tried.
Old Jun 2, 2009 | 02:27 PM
Chuckdimpala's Avatar
Undoing the battery will only temporarily clear code computer will still remember the code and it will come back with in an hr or so. I am fighting this problem right now myself and the car is winning!!! Let me know if any of you guys figure out the best way. I have tried short and long spark plug defoulers and no prevail !!! Pissin me off too
Old Jun 2, 2009 | 02:30 PM
Also clearing the code with the scanner wont work either it will just keep popping up you have to either move the sensor further in or out of the exhaust stream like I said I've been doing this for weeks now and can't get the **** to go away!
mines been off for a whole day now
Old Jun 2, 2009 | 05:54 PM
Here are the codes I get:
Ok the codes are P0004 (Fuel Volume Regulator Control Circuit High) , P0420 (Catalyst Efficency Below Threshold), and P0137 (O2 Sensor Circuit Low Volts Bank 2). But this has to be fixed by either moving O2 sensor farther out or closer to the exhaust stream.
That is my question --- IF YOU DO have a cat-delete ( AND AN EVO X)...HOW did you beat the sensor so it doesn't kick up codes??
I cleared the codes with my scanner but they just keep popping up!
Old Jun 2, 2009 | 05:56 PM
What did you do to get it off, just delete the code?? Also P.M me and let me know when it comes back on, maybe we can crush this problem together since no one wants to help and give advise to how they did it??
