Sponsored by:
Sponsored by: CARiD
Better Windshield Washers ?
Old Jun 9, 2009 | 06:28 AM
WolvieDC's Avatar
Has anyone else noticed what absoulte JUNK the windshield washer sprayers are on the X. I mean it washes my hood more than it gets fluid on the windshield.
Now to me the most important safety features on a care are good tires, breaks and VISABILITY. I know its an EVO and not a MERC or something but come on , windshiled sprayers.
Is anyone else experiencing/noticing this issue?
Right now i'm thinking either the nozzels need to be changed or the washer fluid pump heed a substantiall HP upgrade, maybe running a drive pully of the crank or something .
Anyway I'm assuming that with the Rally history of the vechicle there MUST be some nice after market system that will... oh I don't know... clean your windows.
Does anyone have any suggestions on such a system?
~Thanks
I know this is not a glamous upgrade like "bigger turbo" but ya gota see.
Old Jun 9, 2009 | 06:32 AM
Mj23foreva's Avatar
its probably because the fluid comes from the back, get a bigger pump? lol i dont know
Old Jun 9, 2009 | 10:20 AM
n789db's Avatar
~Thanks
Mine work fine at all speeds I have tried.
Old Jun 9, 2009 | 10:26 AM
Webman's Avatar
I think they are adjusted incorrectly. When going 80, they barely make it over the wipers... When going faster, well.....
Old Jun 9, 2009 | 10:27 AM
WolvieDC's Avatar
Mine don't even make it above the bottom 1/3 of the windshild at 30-40mph.
How do you go about adjusting the nozzles?
Old Jun 9, 2009 | 10:29 AM
ripnbst's Avatar
Perhaps slow down to 65 spray, then speed back up? It sounds like the wind is overpowering the sprayers. Do they work well at 15 mph?
Old Jun 9, 2009 | 10:32 AM
mmartahus's Avatar
they do shoot a little low, i remember seeing somewhere in a technical service manual that they can be adjusted
Old Jun 9, 2009 | 10:36 AM
Webman's Avatar
I still don't think they spray high enough at low speeds. When stopped they are ok, but too much adjustment and you'd be spraying the back windows or car behind you, lol
Old Jun 9, 2009 | 11:30 AM
Dimitri13's Avatar
I don't have any problem with the spray angle, but it leaks like hell. A few people suggested getting Galant spray nozzles.
Old Jul 6, 2009 | 03:36 PM
novec64's Avatar
To adjust the angle of the nozzles you just use a pin. Didn't you guys ever squirt other people around you in high school? lol It's great with a rear sprayer!
Old Jul 6, 2009 | 03:49 PM
rcheung's Avatar
The galant nozzles are awesome. I dont know the spray pattern of the X but if its anything like the 8 with its two weak streams, they stink. The galant nozzles mist the whole windshield like a giant spray bottle.
Old Jul 6, 2009 | 04:34 PM
BlueBlurSTi's Avatar
Mine seem to jet out all in one spot just under half of the windshield. They should spray at about the middle. On my 05 STi the hose got pinched somehow and I had to cut it (it was too long) and then put it back so it wouldnt kink when I closed the hood. Then it worked great. You probably dont have this issue unless your spray is flaccid as a ladyboi
C0dyix
Mar 18, 2017 05:41 AM
fuzzycuffs
Dec 11, 2016 09:32 PM
jrsimon27
Jul 12, 2016 06:36 AM
Dimitri13
May 25, 2009 01:53 PM
kingman4
19
May 29, 2007 06:39 PM
