Sponsored by:
Sponsored by: CARiD
QTP electronic cutout question..
Old Jun 29, 2009 | 09:46 AM
SpeedI2acerX's Avatar
So I'm planning on getting one so I can go stealth. My question is will I have a problem with back pressure from my setup? Basically l'll be running it from my stock exhaust and adding the QTP somewhere before the cat. I'll only be running this at the track. I know there's one guy that's running it. Just want to know what everybody thinks. My main concern would be the pressure that it might have from the stock exhaust.
Old Jun 29, 2009 | 11:52 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
As a suggestion you should get the 3" DP in conjuction with the 3" Y pipe cutout to maximize your exhaust flow when the cutout is open. As for back pressure you have nothing to worry about you will loose a bit of power downlow and possible mid but your topend will be sick. Just make sure you get retuned.
Old Jun 29, 2009 | 11:54 AM
mx4life85's Avatar
I agree with what DBallz said.
I have the QTP cutout welded into my testpipe, and it runs great. Granted, I have a 3" Downpipe.
I notice a bit quicker spool up and when it hits boost its just obnoxiously loud.
You decide if that is good or bad..
Old Jun 29, 2009 | 12:03 PM
Yeah about getting a tune. Do I really need it with a cutout? Like I said I'll be switching back and forth so would I need a tune everytime i have a close them open or just have it tune with it open?
Old Jun 29, 2009 | 12:05 PM
mx4life85's Avatar
It didn't effect my tune much at all. When I opened the cutout I gained about 7whp.
Granted, I have a full TBE. With your stock exhaust you should gain more like 20-30whp.
Old Jun 29, 2009 | 12:57 PM
Please explain why would I see more gains with my stock exhaust? If it'll get me another 20hp I'll be stoked!
Old Jun 29, 2009 | 02:52 PM
JoeyM3's Avatar
what he means is that you will notice more hp gains with the cutout open since you will be running a stock exhaust whereas he is running a turboback already.
you will need to get tune with the cutout open, also since the x's dp is so small, the only way you will be able to run it is if it is on the test pipe, so you would need to get rid of the cat no matter what.
Old Jun 29, 2009 | 07:53 PM
got the test pipe, check. now is it better to put the cutout before or after the o2?
Old Jun 29, 2009 | 09:36 PM
JoeyM3's Avatar
i'd say after, you don't want to throw a cel when you run it open
Old Jun 30, 2009 | 08:21 AM
DrasticK's Avatar
But the rear one is so far back...I want to put mine right at the begining of the test pipe.
Old Jun 30, 2009 | 03:25 PM
That's what I was thinking. There's no room after. Anyone running it before the o2 without throwing a cel?
Old Jun 30, 2009 | 10:33 PM
mx4life85's Avatar
I'm running it before the o2 sensor and I don't throw any cels with it open or closed.
I have the anti fouler mod on my o2 sensor though.
Old Oct 8, 2010 | 11:18 AM
evo9cuhh's Avatar
can you run an accessport tune for the cutout ?
SpeedI2acerX
Evo X Dyno Results
12
Mar 11, 2017 03:44 PM
rodent
Jan 18, 2017 06:54 AM
Black_EVO_MR
Dec 3, 2016 12:07 PM
Evokid03
Jan 22, 2010 10:35 PM
EVO8904
Nov 21, 2007 08:11 AM
