Sponsored by:
Sponsored by: CARiD
Evo X Recaro seat lowering brackets?
Old Aug 14, 2009 | 01:34 PM
jid2's Avatar
Originally Posted by stokEd
I PM'd the guy who makes/sells these and here's what he
I know that guy...
I'm going to try and look at the EVO X one more time. As evident by HKS only lowering the rear the system is not ideal for making lower. The EVO X rails are oriented vertically, and lay directly on the chassis at the front of the seat. This is why you can't lower the front, because the rails are already on the chassis.
I had an idea the other night that I need to investigate but it's more involved than the solution used for the EVO VII-IX.
All this said - it is possible that lowering just the rear could yield good results. If it lowers the pelvis that will get the rest of the torso lowered, improve head clearance and give the lowered field of vision as well as improved alignment with the wheel and shifter. The angle of the legs would be a little more acute, but that might be OK.
I'll look into this a little more.
Old Aug 14, 2009 | 04:41 PM
stokEd's Avatar
Red face
Originally Posted by jid2
I know that guy...
lol... Sorry, didn't realize I'd left your name off the quote.
And glad to hear you're giving it another go.
Old Aug 15, 2009 | 12:19 PM
CICreations's Avatar
I know that guy...
All of use 6'+ guys appreciate your efforts!!!
Old Aug 15, 2009 | 12:41 PM
ob-evosteveo's Avatar
Hell, I'm only 5'10" and I feel like I'm way too high. But, I had Del Sol seats in my old ek, so I prety much got use to sitting on the floor! Wish I could drop the X seats about 1-2".
Old Nov 20, 2010 | 10:01 PM
itsoem's Avatar
So what happen with this? Any updates?
Old Jan 7, 2011 | 05:43 AM
Beeble's Avatar
Kansai make a "best position" lowering rail...
apparently lowers the back up to 35mm and the front up to 15mm
I'm 6'5" and with a helmet on I'm having all sorts of trouble getting into a comfortable and effective driving position!
Tempted to give one a try
EDIT : ooops it looks like i was mislead by a website (Z1 Performance, update your info!)
"best position" actually look slike it RAISES the seat.
and the low position rail only goes 10mm down on stock at the back of the seat - hardly worth it
Old Jan 10, 2011 | 01:04 PM
LiQuIdCrAzN's Avatar
Check out YR-Advance:
https://www.evolutionm.net/forums/ev...o-x-parts.html
I have no idea how much they lower it by, but might be worth looking up =)
Old Jan 10, 2011 | 04:33 PM
stokEd's Avatar
Good find. I'd like to know more about these and if they're still available.
Old Jan 11, 2011 | 02:37 PM
hibby's Avatar
Really, I just wish I could move in closer without clobbering my knee on the bottom of the steering column when I stomp the brakes.
Old Jan 11, 2011 | 04:45 PM
AJ PwR's Avatar
ALEX Japan makes them too and they lower the seat by 30mm.
Old Jan 11, 2011 | 08:47 PM
GetterDragun's Avatar
Do those HKS ones raise the seat? That's what I need.
Old Jan 11, 2011 | 11:33 PM
stokEd's Avatar
Yes.
Old Jan 12, 2011 | 04:07 AM
Beeble's Avatar
And it turns out you are a guy who knows a guy, so to speak.
PM sent
Old Jan 12, 2011 | 05:34 AM
sxng9's Avatar
When I first got into my X, I thought the seating was a bit too high and I'm 5'2", but then I told myself I'll get used to it and I did.
Old Jan 12, 2011 | 02:06 PM
MarkM's Avatar
PM sent
Keep us updated!
