Sponsored by:
Sponsored by: CARiD
Someone Help. I'm stuck.
Old Aug 21, 2009 | 03:56 AM
ZEUS EVOX's Avatar
Hey Guys,
I'm using the AMS AC Delete Kit and I can't seem to find the serpintine belt tensioner. I've seriously looked in the book and called AMS too and the guy didn't know. I'm stuck. Someone if you could help a brother out.
Thanks.
Zeus
Old Aug 21, 2009 | 03:20 PM
robh's Avatar
took 2 sec to find pic in the service manual
Old Aug 21, 2009 | 07:11 PM
mertdinc's Avatar
most new cars are fitted with auto adjusting serpentine belt tension systems. That is there is a moving pulley in the setup that is kept in place with a spring mechanism. That is called auto tensioner. In order to find which one that is move/rock all the pulleys in the system back and forth one of them will be able to move and come back to place. That one is t he auto tensioner pulley. it is kept in it's position with the load of the spring and once the serpentine belt is loaded you can release it to provice tension to the system hence the name implies. As a reminder you may need to apply moderate (dont ask me what torque that is) pressure/force in order to move the pulley.
Old Aug 21, 2009 | 07:19 PM
mr-derer2's Avatar
all u need is a 1/2 inch extension and a 1/2 inch socket wrench. there is a spot to put the end of the extension in. its a square on the arm of the pulley. its real easy.
Old Aug 21, 2009 | 11:16 PM
ZEUS EVOX's Avatar
Thanks for the help guys. Means a lot
Evo Izzy
Oct 30, 2008 05:43 AM
72Tornado
Jun 20, 2008 10:19 PM
honki24
Jun 2, 2006 08:18 AM
2k4EvoVIII
Sep 23, 2004 11:11 AM
