Attention All X Owners.... Do this ASAP....
This also happen to me after about 11,000 miles
The rough idle made it felt like i had cams in the which i didn't. I took it to RRE and they realize the loose hose was the problem. Now the car is back to normal
Every now and then you cross a Mitsu Tech that actually cares about cars and is knowledgeable... Great to see some dealerships see the problem.
Only when off boost. FPR is rising rate, so under boost with no pressure signal to the regulator you have no rising rate and you run dangerously lean.
I have seen this hose come off several cars including my own. Zip Ties FTMFW!
+1
(I'm not taking credit for this picture....)
There is a hose from the Fuel Pressure regulator to the intake manifold. Mitsu did not put any type of clamp on this hose. It will pop off and cause you to run lean, and ruin your idle. It is a simple vacuum line, but is difficult to see when trying to diagnose a problem...
The hose is located near the dip stick. All you need is a couple zip ties....
Heres a pic.
There are one 2 many "My idle is shaky" thread on the opening page..... this is likely everyones problem....
Heres a pic.
Thanks much!
Just checked mine. Luckily the hose was still on, but I put two zip ties on anyway.
Is it ok to have those ends still there or should I cut them?
Also, this is a bit off topic and maybe a dumb question... This hose leads to nothing, that's how it's supposed to be. Right? lol...
