Sponsored by:
Sponsored by: CARiD
Service engine soon
Old Sep 16, 2009 | 10:20 AM
Bear.914's Avatar
Service engine soon
I was driving normal, not beating on the car and all of a sudden the car went into "safe mode" and shut off on the highway and the Service Engine Soon light came on and when I pulled over I shut the car off and then restarted it and the light stayed on and the RPMS where real jumpy and kept going up and down form about 800RPM-2000RPM on its own...ANY IDEAS? car just came back from dealer they replaced clutch,fly wheel,tranny!
Old Sep 16, 2009 | 10:22 AM
Brsox10288's Avatar
What aftermarket parts are on the car?
Old Sep 16, 2009 | 10:25 AM
Clark_Kent's Avatar
Pull the code.
Old Sep 16, 2009 | 10:27 AM
brenner's Avatar
Originally Posted by Clark_Kent
Pull the code.
yep only way to really know. do you have a cat still? sounds like either an O2 problem, or a vac/boost leak
Old Sep 16, 2009 | 10:30 AM
Bear.914's Avatar
Its stock just came back from warranty work, I'm thinking its from not having the boost pill in the hose for the stock boost controller solenoid ?(also i need that hose does anyone know where to buy it ) but the thing is I wasnt even pushing the car, 3krpm when i was cruising and it started bugging.
I fig. it was from NO pill, just wanted to see if there was any other problem going on, this way everyone cant say "yup, its the pill"
Old Sep 16, 2009 | 02:35 PM
Bear.914's Avatar
If there is No pill in, will it cause this ? it happends every say 25-35 miles just happend for the 2nd time, car is now parked again after it being down for 5 months
Old Sep 16, 2009 | 02:42 PM
blk-majik's Avatar
removed pill != stock around 3k rpm is near when you're hitting peak boost. I'd guess its throwing a p1345 code. only way to know is to get it pulled. Try autozone or something. They'll pull the code for free.
Old Sep 16, 2009 | 02:44 PM
Bear.914's Avatar
its not the aftermarket pill, its that little gold stock pill thats in the hose connected to the boost controller solenoid..i mean there must be a reason for it...thanks
Old Sep 16, 2009 | 05:18 PM
sonicrx's Avatar
did your vacuum hose pop off the fuel pressure regulator???
Old Sep 17, 2009 | 12:13 PM
Bear.914's Avatar
i think my MAF sensor is ****ed up
Old Sep 17, 2009 | 12:22 PM
buchnerj's Avatar
Whats the code??
Old Sep 17, 2009 | 01:53 PM
Tunerhead's Avatar
Originally Posted by buchnerj
Whats the code??
Pull the code.
+1
A code of some sort would help!
