Sponsored by:
Sponsored by: CARiD
Wiring question
Old Oct 8, 2009 | 10:10 PM
ScottSpeed21's Avatar
Wiring question
I'm looking for a switched power wire to splice into under the dash that provides power when the key is in the 'On', 'Run', or 'Start' position. Right now I'm spliced into the cigarette lighter, but it doesn't provide power when the key is turned to start the engine, which I need.
Anyone know for sure?
Old Oct 11, 2009 | 04:25 PM
Bump
Anyone? I need to tap my boost gauge into somewhere that will get power in Acc, Run and Start when the engine is cranking.
Does anyone have a wiring schematic?
Old Oct 11, 2009 | 04:29 PM
Smike's Avatar
A cheap volt tester is always handy too.
I used my cig lighter or the LED ashtray lights in my 8 when I needed ACC power.
Old Oct 11, 2009 | 05:24 PM
Yeah I had it spliced into the cigarette lighter. There's power for Acc and On position of the key, but not when you turn it to crank the engine.
I have the new AEM analog boost gauge and when it first turns on, it takes a reading of atmospheric pressure so the needle can set itself at 0. Well, it'll turn on when I turn the key, and then off when I crank the engine and back on when the key rests in the On position. When it does turn back on, the needle zeros itself while the engine is at idle. So when it reads 0 on the gauge, it's actually ~18in/Hg vacuum at idle.
I need somewhere to splice into that will give power while the engine is cranking, so it can take a reading, zero the needle and stay on while starting the engine.
Old Oct 11, 2009 | 07:46 PM
SpeedI2acerX's Avatar
the three switch looking thing to the left of the steering wheel. it should be a green/white wire. thats where i hook up for power.
Old Oct 11, 2009 | 10:51 PM
Thanks, I'll give it a try
Raptord
Jan 8, 2021 07:41 AM
Uscbryan
Evo X How Tos / Installations
Mar 7, 2014 04:32 PM
DangerousDan
Aug 10, 2007 07:00 PM
brentg07
Jun 7, 2005 06:19 AM
19.5PSI
Jul 30, 2003 03:10 PM
