Sponsored by:
Sponsored by: CARiD
Jack Point?
Old Dec 9, 2009 | 12:59 AM
Evolved X's Avatar
Jack Point?
I need to lift my car and put it on jacks so i can get my wheels powdercoated... is this an ok place? I did some research and believe that to be ok but just want some reassurance. Ill try to describe where this is... Just behind the front tires on the metal lip 5 or so inches from the skirt edge of the car. The lip extends to the front of the rear tires where the other jacks are placed.
Old Dec 9, 2009 | 03:29 AM
MrBonus's Avatar
I don't like to use the side jack rails personally. The service manual tells you to jack up the car using the rear differential or underneath the front undertray, there is a black circle up near the front, both of which I've used numerous times with no issue.
Old Dec 9, 2009 | 01:40 PM
ScottSpeed21's Avatar
I use that spot everytime I jack the car, but I use a short piece of wood (2x4) between the jack and the car...it gives a little bit of cusion and spreads out the load more so you don't crush that metal rail. Never had any problems with it on any car.
Old Dec 9, 2009 | 01:52 PM
LaXGSR's Avatar
You should technically have your jack stands a little closer to the wheels. See in your second picture how there are two notches in that lip (and about a 2-3" wide section in between)? That is the best place to put your jack stand. I usually use the jack to jack up where your jack stand is currently, and then put the jack stand in between the notches that I described.
Old Dec 9, 2009 | 02:01 PM
katchup's Avatar
I use the side rail, i dont like too, but when your car is lowered you dont have a lot of choices
Old Dec 9, 2009 | 03:36 PM
steven88's Avatar
mine is exactly where the OP has his....exxcept mine are in between the notches.....i feel safer with it between those notches because it spreads the car's weight more equally...haha
Old Dec 9, 2009 | 05:45 PM
Evolved X's Avatar
Thanks for the posts. Wheels are getting coated tomorrow!
Old Dec 9, 2009 | 06:39 PM
lowkey's Avatar
Registered User
Yeah, have a little mercy... metal to metal... ouch! I use hockey pucks with slits cut in them.
Old Dec 9, 2009 | 06:50 PM
MikeColangelo's Avatar
Yep, that's the ticket. With Evos, a floor jack on the pinchweld usually results in a bent pinchweld unless you're using a slitted block of wood or hockey puck. You can bend them back but it's a hassle.
Old Dec 9, 2009 | 07:14 PM
EsRt2evo's Avatar
I put mine between the two notches as well. I don't use a jack though, I usually turn green and pick it up myself.
Old Dec 11, 2009 | 10:42 AM
Evolved X's Avatar
So far so good... car should be coming down this afternoon! Thanks for the posts guys!
Old Dec 19, 2009 | 03:09 AM
LakerRaider's Avatar
i never jack from the rear cuz i dont know where, one time i started to but some metal started bending upwards lo so i stopped... but i want to change my diff fluid soon...
Old Jan 2, 2010 | 07:54 AM
imboostinnow's Avatar
lol "you wouldn't like me when im boosting "
Old Jan 2, 2010 | 09:19 AM
sonicnofadz's Avatar
Don't do it, those skinny little thing will permanently crush, leaving your underbody ruined.
Old Jan 2, 2010 | 01:34 PM
►EvolutionX◄'s Avatar
This
Picture 3 is ok, rest of them need to be in between those notches, the pinch welds are doubled up there and are stronger and more resistant to bending, it will also distribute the weight of the vehicle more evenly and keep your arms and legs attatched to your body when the vehicle doesnt falll down and sever one.
Evolved X
16
Dec 30, 2015 12:21 PM
MDH-005
Feb 4, 2014 10:34 AM
MDH-005
Jan 9, 2013 11:43 AM
1BADSS/SC
Nov 30, 2010 03:31 AM
turbotrapi
Nov 3, 2010 05:10 PM
