Sponsored by:
Sponsored by: CARiD
View Poll Results: Have you experienced hesitation or misfire after driving in rain?
Yes, I have experienced this driving in light mist / wet roads after rain
6.33%
Yes, I have experienced this driving in a hard storm
7.59%
I have never experienced this from driving in the rain
68
86.08%
I do not drive my Evo in the rain on the interstate
3.80%
Multiple Choice Poll. Voters: 79. You may not vote on this poll
Driving in the rain?
Old Jan 1, 2010 | 12:47 PM
alex3dworld's Avatar
there is a few plugs unprotected again water splash under the hood. even if there is no direct way to get them wet, a heavy rain+ speed can make water get to every place. buy some good high temperature electrical tape and finish the work. in most of the plugs the area were the cable is connecting to the plug is open, sometimes facing up.
I had a bad experience with a boost sensor under my hood because a heavy rain. I installed the sensor port facing up (my wrong). the water went down following gravity and enter the port. i burned the sensor, de gauge went crazy, i had to pullover under the rain,
so......
yes under heavy rain + 60-70 mph speed you can expect water were you should not expect it. you should double check for open electrical connections and fix it.
Old Jan 2, 2010 | 12:09 PM
sonicnofadz's Avatar
Make sure that you have checked for any loose connections on the intake piping, and any other vaccum hoses. Check for boost leaks. Also take note of what aftermarket parts or modifications you have installed that could be causing this condition.
Seth_Horton92
Feb 9, 2017 07:13 AM
tsidrift1
Dec 3, 2012 08:07 AM
Jamerico
Jan 24, 2011 05:38 PM
jcdevo67
18
Dec 14, 2008 01:42 AM
AMS
Automotosports - Illinois
15
Oct 23, 2006 10:34 AM
