Sponsored by:
Sponsored by: CARiD
K&N filter for x
Old Dec 31, 2009 | 08:58 AM
3dman1's Avatar
K&N filter for x
Is there any problems with using the k&n panel filter in a x that i should be aware of? How does it rate for air flow ?
Old Dec 31, 2009 | 09:13 AM
evo_soul's Avatar
just becareful with the amount of oil used. there have been reports of the Mass Air Flow sensor being ruined due to the oil kit. Its likely to happen more so with a turbo set up than a regular NA engine.
Others may be able to advise you better on this.
Old Dec 31, 2009 | 09:59 PM
EvoIXMR's Avatar
I did quite a bit of research on panel filters and went with the perrin. Other one I considered was Cosworth. The Ralliart was too expensive...
Old Dec 31, 2009 | 11:01 PM
Ltdanish07's Avatar
+1 on the MAFs going bad.
Im running the HKS and all seems good to me.( Its a dry filter) Plus your BOV will be louder
Old Dec 31, 2009 | 11:41 PM
PCToolsWiki's Avatar
I run the HKS Hybrid filter on my 2010 Ralliart.
Old Jan 1, 2010 | 07:55 AM
mlomker's Avatar
I went with AFE since it's a dry filter. A number of people have had repeated MAF failures from oil coming off of an oiled filter.
The stock airbox flows plenty of air...probably adequate for anything short of a T3 upgrade. If I had to do it all over again, I'd go with the AEM intake (a conical filter inside of a replacement air box).
Gibby860
137
Jan 25, 2020 11:08 PM
RedSER13
Jun 22, 2014 04:48 AM
rrkpitt15
23
Aug 21, 2012 02:20 AM
EKtoEvoX
Evo X Dyno Results
63
Jan 27, 2009 09:17 PM
hoongss
45
Aug 6, 2008 09:56 PM
