Sponsored by:
Sponsored by: CARiD
Manual at home - Red ((!)) - Brake?
Old Jan 12, 2010 | 11:32 AM
saytheb's Avatar
Hi all.. I am pretty sure I already know the answer, but I want to confirm.
I am getting the following red symbol: ((!)) and my E-Brake light is flipping on.
What gives? What's the manual say is the cause?
Thanks!
Old Jan 12, 2010 | 11:39 AM
mike640's Avatar
I'm pretty sure that symbol is for low tire pressure.
Old Jan 12, 2010 | 11:41 AM
lancer0220's Avatar
its cold in Colorado fill your tires with some air get them back to 32psi or w.e. the evo calls for
edit : pretty sure the tire pressure light is yellow...so this must not be it.
Old Jan 12, 2010 | 11:44 AM
saytheb's Avatar
This warning shows up on braking/acceleration, then blips off. Don't think it's TPS.. manual states exactly what it is, but I don't have it in the car.. =(
Old Jan 12, 2010 | 11:48 AM
kwanza's Avatar
I had a similar issue when I removed the console housing for the e brake. There is a clip for the sensor, which can bind if it is assembled improperly. This can cause the e brake light to come on when the brake is off.
I would take the console apart and check the wiring to the brake.
Old Jan 12, 2010 | 11:55 AM
saytheb's Avatar
Thanks - I had taken the console off in the past, I'll look into this.
Old Jan 12, 2010 | 12:29 PM
Toxin's Avatar
Low brake fluid?
Old Jan 12, 2010 | 01:21 PM
c_reber's Avatar
Originally Posted by Toxin
Low brake fluid?
This.
Old Jan 12, 2010 | 03:21 PM
saytheb's Avatar
Low brake fluid?
Facepalm.. didn't even consider looking, ugh. I'll also put that on the checklist.
Old Jan 12, 2010 | 05:03 PM
saytheb's Avatar
Low brake fluid?
Winner.
Thanks all. Pads are worn way down, brake fluid isn't even visible in the reservoir on driver side firewall. Grrr.. new pads time.
Old Jan 13, 2010 | 01:40 AM
Toxin's Avatar
You're welcome haha! =P
Sometimes the obvious problem becomes too obvious. It says brakes, why look at something else
beetle_orange
May 25, 2017 11:14 AM
driftnburn
Apr 8, 2016 06:02 AM
tliT
Aug 18, 2015 11:14 AM
kyle wade
Lancer Tranny/Drivetrain Tech
Oct 21, 2014 04:24 AM
AM-EVO
12
Jul 16, 2009 04:13 AM
