Washer fluid reservoir capacity = 1+ Gallon
Hmm.. maybe I'm just an idiot, but went to fill up my fluid today and it was almost full. Tried using the washer lever again, and it worked this time. I'm guessing maybe the dealership in CA used regular fluid and somewhere in the lines or nozzles it froze up while sitting at the shipping lot overnight.
And thanks to Hotdog's great faith, I was able to top 'er off straight from the bottle without spilling a drop, lol.
Plus, 3 gallons might even last me more than a month around here.. maybe.
Physics lesson for the day.
Lol, thanks!
Guess that makes sense.. I just always figured that weight distribution was Mitsu's reasoning behind putting both the battery and washer reservoir in the trunk. Now I have no idea why they would.. maybe to make more room in the engine bay for parts related to the turbocharger?
ETA: Wouldn't a 100% full washer reservoir be decent weight-distribution, since there wouldn't be much, if any, movement of the fluid?
Lol, thanks!
Fluids don't help with the weight distribution at all. Think of a bottle of water that is half full, no matter how you turn it the water or fluid inside it wants to maintain a constant level, much like any fluid that is at rest. But when an outside force such as a centripetal force acts upon said fluid, the fluid wants to move outward from the center of rotation. You can demonstrate this by filling up a bottle of water and spinning it around in circles using your arm or a string. When the force is no longer acting upon the fluid in the bottle it will continue to move or slosh around until it has reached a steady state. You can demonstrate this by allowing the bottle to just stand still after spinning it. Not trying to sound like a d*ck just trying to be thorough with my explanation. I took a sh*t ton of physics in college.
If you corner weight an Evo X with a full tank of gas. Then do the same thing with 1/8 tank of gas. You'll find the weight distribution from front/rear will change by about 100lbs (12 gallons of fuel = approx 100lbs). The Evo X is about 57/43 front/rear distribution with all fluids full. If you remove 100lbs of fluid from the rear, that would change the weight distribution to somewhere around 58.5%/41.5%.
Apply that same concept to taking 100lbs of fluid from the front and move it to the rear. In fact, that would have a duplicate affect on weight distribution since you're losing from the front buy gaining in the rear.
That's an extreme example especially when compared to a 1 gallon washer reservoir, but used to illustrate the point
The movement properties of a fluid do not negate the placement of the fluid and its affect on weight distribution.
Not trying to be a *****, but are you sure you can make that statement so definitively?
It is very easy to fill your windshield washer fluid, all it take is a little common sense. You open the trunk, take the cover off for the spare (including carpet) and then.....tada you can fill it and never spill a drop. This is the way I fill it and have NEVER used a funnel, and I have NEVER spilled it at all.
