Sponsored by:
Sponsored by: CARiD
Washer fluid reservoir capacity = 1+ Gallon
Old Feb 4, 2010 | 05:57 PM
  #31
supergengo's Avatar
Originally Posted by Get Rad
You didn't sound like a ***** at all and I actually learned something new, which is the weight distribution of the evo x. You have to read what I said though a little better. I stated that " The fluids don't HELP with weight distribution" not that its doesn't affect it. The weight is always varying. You want it as balanced as you can get it, but when you have variables like fluids which are always changing amounts they do affect how the car will handle.
Don't forget that the fluids are constrained within rigid containers. As such the weight and momentum of the fluid will be transferred to it's container, which is connected to the frame.
Sloshing will create momentary variation to weight distribution within the container.
Consumption would create variation in total mass and create more room for sloshing.
Based on the quanties of fluids in the car and the shapes of the containers, I'd guess that the variability due to sloshing has a negligible impact on handling.
(By the way, humans are mostly water in a container and we slosh in the seat!... something to think about)
Old Feb 4, 2010 | 05:58 PM
  #32
Jblade's Avatar
i can't believe this thread turned into a "what's the best way to fill the tank up/physics lesson of the day (which was a good refresher btw)" discussion. This is evom guys! I'm thinking to myself "this is great to know, but how do i get that JDM/EDM/AUDM tank so I can hold more meth!
Old Feb 4, 2010 | 10:42 PM
  #33
AFD's Avatar
AFD
Originally Posted by monkey_187
It is very easy to fill your windshield washer fluid, all it take is a little common sense. You open the trunk, take the cover off for the spare (including carpet) and then.....tada you can fill it and never spill a drop.
On an evo x?? I didn't have to remove the spare tire cover or carpeting at all.. just pop off the plastic cover (on the backside of the rear seat).
Old Feb 4, 2010 | 11:02 PM
  #34
Get Rad's Avatar
That is just common sense though lol.
Old Feb 26, 2010 | 09:06 PM
  #35
Jblade's Avatar
Hey Tephra, in my earlier post about using it to hold meth, I kinda just now realized i was only half joking. Is it possible that you have the partnumber for the AUDM wiper fluid reservoir? RusselM from MitsubishiParts.net may be able to get it for me if he has the right number
Old Feb 26, 2010 | 09:13 PM
  #36
tephra's Avatar
Not on me.
But I can probably find out.
let me email someone in the know
Old Feb 26, 2010 | 09:39 PM
  #37
shrtstuff89's Avatar
Originally Posted by AFD
I'm only half-way through the manual, and didn't see anything other than where to fill it, and a recommendation to use anti-freezing washer fluid in colder climates. With everything else going on in the middle info display, you'd think it'd be there?
ive always know/been told not to use the typical blue windshield washer fluid. always heard the yellow/green fluid has a lower freezing point than the blue.
rain-x bug remover 32* F
rain-x deicer (yellow) ~ -40* F
rain-x deicer (orange) -25* F
blu coral -25* F
im bored so i found a couple of kinds
Old Feb 26, 2010 | 09:45 PM
  #38
Jblade's Avatar
Originally Posted by tephra
Not on me.
Thanks man, I appreciate it!
Old Feb 26, 2010 | 10:38 PM
  #39
gunzo's Avatar
8260A147 Washer fluid tank
Old Feb 27, 2010 | 07:41 AM
  #40
Hiboost's Avatar
Originally Posted by JAMiLiTUDE
This might sound stupid but is there a warning indicator that comes on when the level is low?
I ran mine dry the other night during winter driving and there was no "low level indicator warning" anywhere to be found. That larger capacity tank from the other markets looks perfect for setting up a dual use water injection setup.
Old Feb 27, 2010 | 12:15 PM
  #41
supergengo's Avatar
I agree, but for me, cost would be the deciding factor. If the part is over $150USD (as I'm sure it will be), I think it's not worth it.
The tank is pretty large too, so you may have to rethink where you can mount the pump for the meth/H20 (if you wanted it near the tank anyhow).
Old Feb 27, 2010 | 08:17 PM
  #42
Jblade's Avatar
This is the part number for the Australian Domestic Market tank (AUDM)? Tephra posted a pic of it earlier.
Old Apr 17, 2010 | 08:11 AM
  #43
RussellM's Avatar
Plat Vendor
Old Apr 18, 2010 | 02:45 PM
  #44
Jblade's Avatar
it should be less than half that, hit up RusselM
Old Apr 23, 2010 | 03:40 PM
  #45
Jblade's Avatar
just got the tank today, now i need the Devil's Own kit
Mark1si
Mar 17, 2017 07:44 PM
03chi-town0Z
Oct 17, 2013 04:51 PM
ilikeboost
14
Nov 24, 2010 11:04 PM
adammartini
Aug 26, 2009 05:48 PM
EvolNinja
Jul 28, 2009 11:13 AM
