Sponsored by:
Sponsored by: CARiD
Cold Weather Starting
Old Feb 11, 2010 | 08:33 PM
dj3po's Avatar
Has anyone else heard a weird noise out of the engine when starting in cold weather (talking like mid 20's)? Almost sounds like a belt screech. It goes away after the car warms up. So over this winter...
2008 MR...only mod is a HKS drop in filter...
Old Feb 11, 2010 | 09:58 PM
AFD's Avatar
AFD
Mine makes all kinds of weird noises. It's been under 30-degrees since I've had the car, so hard to say if it's weather-related or not.
Everyone usually says that Evo noises are normal, but if it bothers you, take it to the dealer to get checked out.
ETA: And maybe swap back your OEM air filter if you go to the dealership, so they don't blacklist you for having crazy racing mods, lol. =)
Old Feb 11, 2010 | 10:28 PM
shizblam's Avatar
Evos make weird noises, but I've never heard of belt screeching being normal... take it to the dealer and have them check it out if you're worried about it... it's not like you've got anything to hide.
Old Feb 11, 2010 | 10:30 PM
Rocky2's Avatar
Serpentine belt slipping? At least I had that problem in another car, non-evo.
Old Feb 11, 2010 | 11:19 PM
Jyrk's Avatar
i believe from what has been posted on this noise, its the SST tranny.. I believe every RA and MR's get this at low temps when the car is warming up.
Old Feb 12, 2010 | 12:57 AM
Hassan!'s Avatar
My gsr has same problem at -20, The solution is to use 0w30 oil.
Old Feb 12, 2010 | 06:13 AM
Hiboost's Avatar
I've heard the occasional clunk when starting in sub 20* F weather if the car has been sitting outside. Sounds like oil isn't protecting everything for the first second of cranking and then all is well... still it's unsettling though.
Old Feb 12, 2010 | 09:23 AM
cnj4ever's Avatar
Cool
i get a weird noise off and on when the fan cuts on and off
Old Feb 12, 2010 | 09:43 AM
Rands's Avatar
Mine as well. It sounds like a high pitch whine/squeal on start up, then give it about 5 seconds or so and it goes away.
jheff
Jan 10, 2017 07:07 AM
supak1111
Dec 22, 2016 11:35 PM
vteckiller
21
Apr 16, 2015 07:58 AM
zebra4
Jan 21, 2013 07:16 AM
bboypuertoroc
16
Mar 22, 2011 11:22 PM
