Sponsored by:
Sponsored by: CARiD
Dp install
Old Feb 18, 2010 | 10:06 PM
alktrio06's Avatar
Dp install
Ok, so I broke down and had a shop install my dp. After reading about the hard time people have been having putting these on, I figured 120 was worth it. Anyway, is there anything I should check on after the install to make sure everything is ok? I know from putting on my exahust, that you should tighten any bolts after driving for a bit. Anything else?
Old Feb 19, 2010 | 04:46 AM
wiretap's Avatar
Which shop did you take it to? (I'm from Michigan near you as well) As far as checking on anything, just make sure everything is tight after a day or two of driving and you should be good to go.
Old Feb 19, 2010 | 06:48 AM
alktrio06's Avatar
I went to speed industry. I got a really good deal on the install too.
Old Feb 19, 2010 | 08:11 AM
lowkey's Avatar
Registered User
If this is a combo a O2/ DP that is a heckuva good price. If it's just the DP, they robbed you.
- There is a link here somewhere (search) for the shop manual, locate the Turbo diagram and indentify all the bolts;
- Use a 14 mm socket / wrench, check all the bolts and nuts are tight on the turbo (if it's a O2/DP) ;
- Put your car in a area with bright light or use a work light and check the pipes are not touching anything, like heatshields etc;
- Check the bolts and nuts where the DP meets the Cat;
- Drive it a few days, then check for black soot leaking out at the O2 sensor bung and flange were the DP meets the cat.
- Let the car sit idling, then lie next to it and listen for leaks.
SpardaVR4
17
Sep 4, 2016 04:30 PM
digitalskillz
31
Jan 16, 2016 06:09 PM
OSprt
Outlander Sport
44
Oct 24, 2013 03:49 AM
porsherules911
10
Aug 9, 2008 01:45 PM
EvolNinja
Apr 8, 2008 12:38 PM
