Sponsored by:
Sponsored by: CARiD
Need Help ASAP
Old Feb 21, 2010 | 09:47 PM
Djstorm100's Avatar
Need Help ASAP
So, I'm going to dealership tomorrow to get the replace of the air back, fuel rail and the awd computer flashed. I hardly drive the car so it wasn't on my top priortiy. Also to top off my fluid that is in the rear passenger side in the trunk.
The TSB thread hasnt been updated and well the dealer said he would look at anything that came up to my attention.
I would like to know what other TSB or Recall out there other than the ones I have listed
Recall:
Fuel rail
Airbag senor
TSB
ECU flashed RevIII
ECU flashed for hesitation above 5k
Fuel pump reail
Timing cover
Is there anything else?
thanks
Old Feb 21, 2010 | 09:50 PM
Bawb3's Avatar
Fuel Relay (If that's not what you meant about the fuel rail).
Old Feb 22, 2010 | 08:23 AM
Djstorm100's Avatar
They are two different ones. Anyone else?
Old Feb 22, 2010 | 08:29 AM
murlo26's Avatar
check to see if you have any oil leaks. There is a TSB out for the timing cover (mine was leaking, getting fixed now) leaking oil.
I didn't go to the dealer though because I did cams which might have sped this up for me. Also I already had the turbo/manifold off so it was right there to fix.
Old Feb 22, 2010 | 11:26 AM
Djstorm100's Avatar
Thanks I'll have them look at it and I my self will look at it. the under panel (plastic cover on the bottom was clean)
Old Feb 22, 2010 | 11:53 AM
murlo26's Avatar
No problem, they told me the oil gathered near the oil pan and he traced it up there.
jrsimon27
Sep 14, 2010 10:18 AM
tsi1991awd
Feb 2, 2010 03:12 PM
rAWjAW
Oct 14, 2009 11:39 AM
crebain
18
Jul 26, 2008 08:14 AM
EvoDan2004
Sep 25, 2005 06:21 PM
