Sponsored by:
Sponsored by: CARiD
passing emissions - question
Old Mar 8, 2010 | 07:24 AM
pd9000's Avatar
Regarding inspection;
I have invidia DP with HFC and Invidia N1 catback, just wondering if i should use cobb ap to flash back to stock map? or should i leave it with the stage 2 map?
Thanks
Old Mar 8, 2010 | 08:23 AM
Sufu's Avatar
I don't think it's worth the hassle. The only emissions check is really done through OBDII and as long your not running a nasty smelling test pipe or throwing codes I think any inspection station would pass you. Just stay away from BP - those guys woulden't pass my stock Evo for some BS reason.
Old Mar 8, 2010 | 09:50 AM
sohcpunk's Avatar
I also heard it's legal to have an open filter intake for turbo cars. Can anyone confirm this?
Old Mar 8, 2010 | 10:06 AM
Standing Z's Avatar
cali is a different beast than any other state. In Illinois I passed without a cat just fine. Had a mechanical fix in there. My friend with an 06 STi passed with his stage 1 AP also catless. He had an option in there to disable his rear o2 sensor from throwing a code.
Old Mar 8, 2010 | 10:42 AM
Webman's Avatar
Strangely, the readings off of the Evo (stock) were higher than the readings from my 15 year old pickup. I had them both tested on the same day. I imagine with the AP, you would get lower readings, as it's not running so rich.
Old Mar 8, 2010 | 04:49 PM
pd9000's Avatar
so i'm an idiot, I flashed the car back to the stock map using the cobb ap, thinking that may help me pass inspection, i didn't realize this would require the the car to be driven a few cycles before the o2 system would be ready to pass inspection
so i took the car and it failed since the car hadn't been driven a few cycles after the reflash. o2 system not ready
So i drove the car some more and i got the 'service engine soon' warning (since im using the stock map with new downpipe with HFC)
my options:
1) keep stock map on and just clear the code using the cobb ap, or does that clear the ecu like a reflash does? requiring me to drive the car for awhile ? i need to clear the code but have the o2 system in a 'ready' state
2) flash to the cobb stage 2 map, i will not get any type of check engine light - but do these maps disable all of the o2 monitoring?
3) reinstall my stock downpipe with stock cat
thank you
master c
Oct 20, 2013 04:06 PM
IX_MR
Jan 16, 2013 07:44 PM
jojobanks
Oct 25, 2010 05:55 AM
bbyevo8u
Mar 7, 2010 07:04 AM
