Sponsored by:
Sponsored by: CARiD
help me diagnose my evo x problem
Old Mar 19, 2010 | 11:02 PM
bryanlo's Avatar
Hello guys, my evo X started to act up on me. here are my symptoms, my rpm jumps from 3k to 4k sorta like a boost kicked in. while jumping rpms I do feel some power kick in then it stablizes and does it again at higher rpms. it will do this through 1st-5th gear. but I don't feel the evo X power being 100% there. there is also a slight high pitch sound I can hear from the engine bay on cold starts.
Here are my only updrades
BC br coilovers
rota wheels
cobb AP
Here are my problems
I had some allignment issues and my rear tire went out fairly quick
I now have 6k on the car and my rear tires are bald and need replacement soon.
I'm thinking its my clutch but my gears go in fine without any problems. could it be my rear wheels just sliping due to lack of grip? also if I just drive slow and easy on the gas I don't see the rpms jumping. any ideas would help. thanks.
Herby
Old Mar 19, 2010 | 11:14 PM
iamblue03's Avatar
did you load the right map on your cobb?
i dont think alignment affects your issue, wheel slip does not make your rpm jump.
maybe it's the boost kicking in because your right foot?
Old Mar 19, 2010 | 11:19 PM
bryanlo's Avatar
I did load the correct map. I have stock so I did stage 1 stock on 93 octane..the car had been running fine for weeks. My right foot remains steady and it has never jumped like that ever since. perhaps I'll reload stock map and see if rpms still jump.
Old Mar 20, 2010 | 06:05 AM
bryanlo's Avatar
uninstalled the cobb ap this morning and returned to stock and problem still exist..has this happened to anyone?
Old Mar 20, 2010 | 06:56 AM
GasHead's Avatar
Time for a clutch
Old Mar 20, 2010 | 07:23 AM
atombomb33's Avatar
EvoM Community Team
Try putting the car in 5th gear at around 45-50mph. Get on the gas. If the rpms rise and the car doesn't feel like it's moving, you're clutch is gone. If the car accelerates fine, then I'm not sure what it could be.
Also, what type of alignment issue did you have that only your rear tires were worn in 6,000 miles? Did you ever rotate your tires? What parts of the specs of your rear alignment were out of spec? Can you post the numbers from the alignment print out?
Old Mar 20, 2010 | 09:01 AM
ikt's Avatar
ikt
have you checked for vacuum leaks?
Old Mar 20, 2010 | 10:16 AM
bisdakr's Avatar
clutch?
Old Mar 20, 2010 | 06:13 PM
bryanlo's Avatar
got on 5th gear and car jumped that same way in rpms but I feel power when it jumps rpms. the car still moves and I feel like theres a jerk when the rpms jump. I will check for vacuum leaks. I lowered the car a lot using bc br coilovers and didn't allign and also neglected rotation. I got it alligned but they didn't give me allignment specs. I will call the place to get the allignments specs.
Old Mar 20, 2010 | 07:16 PM
4G63pride's Avatar
CLUTCH mine did the same thing.. Intial WOT it would jump up then and then go back down and be fine..
Old Mar 20, 2010 | 10:42 PM
bryanlo's Avatar
really? I was hoping it was something else, at 6k clutch is gone? that's some crappy clutch..how much did it run to replace your clutch?
Old Mar 20, 2010 | 11:12 PM
terry2543's Avatar
Labor = 400-500
clutch kit = 700 ish
so about 1000-1500
Old Mar 21, 2010 | 01:00 AM
bryanlo's Avatar
ouch...i'm guessing mitsubishi wont pay for any of it.
Old Mar 21, 2010 | 02:04 AM
motox502's Avatar
Dont blame a clutch that has lasted MANY people on this forum for over 20k miles. Blame yourself.
hotdog's Avatar
It's a wear item. No.
Though, really, at 6k miles, that's damn early for a clutch to go. Did you abuse the hell out of it? Is this your first manual car?
