Sponsored by:
Sponsored by: CARiD
Cigarette lighter problem?
Old Apr 24, 2010 | 03:15 PM
Djstorm100's Avatar
when I plug in my charger for my phone it lights up green but i've notice at times it will start flashing as if the power is going on and off really fast..anyone else notice this? or have this issue?
Old Apr 24, 2010 | 04:03 PM
wiretap's Avatar
Never had that issue, but you can pop the center console open very easily and check if everything behind is connected firmly.
To take the center console apart, all you have to do is pop the little coin tray out with your hand, then face your palm toward the front of the car and yank up on the cup holder portion so it pops out, then you'll have access to the screws to take off the part where the cigarette lighter is. It's easiest to unscrew your shift knob so you can lift the panel off easier.
Check your fuses too to make sure they are firmly in place and not smoked.
Old Apr 25, 2010 | 12:39 AM
lancerarmstrong's Avatar
its probably your charging cord. a fuse only blows when it draws too much current, IE if your charger jumped the gap between the 12v center pin and ground sides or a coin fell in there. i've seen that at work all too many times. with how simple of a circuit this is, its the only thing you should question
Old Apr 25, 2010 | 01:15 AM
Djstorm100's Avatar
I tired it in my truck and it didnt do it. There is nothing down in there, but I'll replace with the one in my truck and see if it does it.
Thanks guys
Old Apr 25, 2010 | 11:21 AM
iceman1680's Avatar
If the light is flashing sporadically rather than rhythmically then it's probably a loose connection. Does it happen while driving? That would make sense if it does. If it does it while stationary then I'm not sure.
Old Apr 25, 2010 | 01:06 PM
Djstorm100's Avatar
yea while driving.
Old Apr 25, 2010 | 01:26 PM
stokEd's Avatar
Have you tried this? I've never had any trouble with mine, but this was my first thought.
bigturboevo80
Aug 27, 2010 07:08 PM
Snjolfur
12
Nov 16, 2008 08:09 PM
Jimmy242
Apr 4, 2008 11:45 AM
zeus1
Mar 28, 2008 12:11 PM
shinobee1
Lancer Troubleshooting
Sep 8, 2007 05:51 AM
