Sponsored by:
Sponsored by: CARiD
AEM Water / Methanol Injection Kit
Old May 7, 2010 | 12:04 AM
jackevox's Avatar
HI is aem water/ methanol injection really bad for your car???
http://www.aemelectronics.com/1-gall...ection-kit-691
can you guys give me some input on the setup??? Is this safe??? I hear that is just as bad as NOS...BAD for your engine......
can i install it on a stock evo with no other mods OR is there any MUST upgrades??? PLEASE help i need as much input RIGHT NOW I ONLY HAVE TURBO BACK EXHAUST ANd INTAKE AND WAS THINKING OF THE WATER INJECTION IS THIS OK to PUT on FOR JUST WHAT I HAVE ALREADY MOD.....??? oh yeah i have an evo x THANKS GUYS
Anyone have this AND how long you had it for????
Old May 7, 2010 | 01:45 AM
hotdog's Avatar
Your capitalization usage confuses me.
At first it sorta made sense, it's like, oh, he capitalized BAD, but then it just got silly.
Old May 7, 2010 | 04:28 PM
IrvineXGSR's Avatar
i ran water/meth injection on my car. they've been using this stuff for a LONG LONG time. used to use it in drag cars, etc.
in case you don't understand, which im assuming you dont, water meth injection is sprayed as close to throttle body as possible in the LICP. it cools down the charged intake air temp. thus you tune for greater timing and higher levels of boost.
in your case, i would get rid of the cat and run water/meth.
also, on a side note, i'm currently selling my AEM 1 gal meth kit if you're interested. PM me.
i decided to run a different setup for my car.
http://www.socalevo.net/index.php?op...&topic=96760.0
Old May 8, 2010 | 12:44 AM
jackevox's Avatar
help more input please is it GOOD or BAD for your car???
Old May 8, 2010 | 01:09 AM
tephra's Avatar
when used correctly it shouldn't have any negative impact on the car...
and to maximise the evaporative effect you should install the jet nozzle as far from the throttle body as possible, but obviously after the intercooler...
Old May 8, 2010 | 01:28 PM
IrvineXGSR's Avatar
oh. my bad. i was told close to throttle body. oops.
Old May 9, 2010 | 06:51 AM
rrkpitt15's Avatar
I was looking to get one myself and i have read nothing but good reviews about it
Old May 9, 2010 | 07:46 AM
kakasensei's Avatar
isnt running meth like having a higher octane gas?
Old May 9, 2010 | 07:48 AM
tephra's Avatar
the advantage is 2 fold:
1) you get the evap effect from water/meth which cools the intake charge
2) you get the knock suppression from water/meth (water has a VERY high octane number )
Old May 9, 2010 | 08:06 AM
Messidona's Avatar
HI guys.. for those who have installed this kit, i am going to have this installed. Any suggestions in terms of injector placement. I have read and searched the site and there are so many differing opinions. Also, what size would you all recommend for the injector size that that AEM kit comes with? small, med, large?
Old May 9, 2010 | 05:13 PM
bouncintiga's Avatar
also i think it helps in cleaning the motors internals, no?
Old May 9, 2010 | 10:45 PM
jackevox's Avatar
does the injector go into the lower ic pipe?? so do you have to upgrade the LICP and weld the injector on??? what do you have to do to install water/ meth???
Old May 9, 2010 | 10:46 PM
jackevox's Avatar
What do you mean is the aem water/ meth is not good for your car???? please explain.... OR can anyone explain????
Old May 10, 2010 | 12:22 AM
IrvineXGSR's Avatar
i ran the aem with the largest nozzle. and i welded a nut and screwed the nozzle in on my LICP. listen to tephra and put it "and to maximise the evaporative effect you should install the jet nozzle as far from the throttle body as possible, but obviously after the intercooler...". I thought it was closer so my nozzle was close but i'm sure hes correct over me. hahahah
like anything adding more power, its adding load/stress to your engine components so technically that is not good for your car. depends on your definition of bad. its not gonna hydrolock your motor if thats what youre asking.
"when used correctly it shouldn't have any negative impact on the car..." again tephra.
on a side note, if anyone is looking for a aem kit, i'm selling mine. pm me.
Old May 10, 2010 | 12:29 AM
tephra's Avatar
I'm just quoting Richard from Aquamist...
and I very much doubt he is wrong
