Sponsored by:
Sponsored by: CARiD
Grinding
Old May 14, 2010 | 08:44 AM
CaptainAsia's Avatar
Grinding
Hello, I recently got my 2010 WW Evo GSR and love it, but I have noticed sometimes on upshifts it grinds a little in second and third gears, I know this probably isn't normal but has anyone else had this problem?
Old May 14, 2010 | 09:01 AM
koach's Avatar
Every Evo ever has this problem. Some say changing the transmission to something like AMSOil works. others swear by a short throw shifter with new bushings, a weighted shift knob, or a combination of all of those.
But from what I gather, even if you did all of that it just makes the problem less, it doesn't completely fix it.
Old May 14, 2010 | 09:15 AM
CatalystGod's Avatar
He means "transmission oil"
Just deal with it. I have a Short shifter with metal bushings that was supposed to make things better. Guess what, it did not. It happens however only when cold. Try to shift with authority and that way, you might feel some clunkiness, but you won't grind.
Old May 14, 2010 | 09:50 AM
Get Rad's Avatar
This post should be closed, Welcome to the world of an Evo love it or leave it.
Old May 14, 2010 | 10:09 AM
Payden's Avatar
That is pretty normal
Does it get better after the car warms up?
As stated, trans fluid swap should help, short throw and bushings should help. Start with the fluid as it is cheaper.
Old May 14, 2010 | 10:18 AM
Methodical4u's Avatar
as i've stated MANY times myself... when you push the clutch in and notice the RPM's will rise a hundred or 2. Let them rise and then when they fall back, then shift.
Old May 14, 2010 | 11:07 AM
CC16's Avatar
Thats fine and all, but during a spirited drive most folks arent wanting to wait around a few seconds for the RPMs to go up and down to get into a gear without it sounding like the world is ending under the boot.
Old May 14, 2010 | 11:16 AM
ugakirk's Avatar
Redline fluid will help alot. Then get a Short shifter and bushings.
Old May 14, 2010 | 11:54 AM
Yes, I did notice this only happens when I first start driving, for the most part. As for love it or leave it, I love the Evo, just wanted to make sure I wasn't doing anything wrong...
Old May 14, 2010 | 12:19 PM
Nauticabri's Avatar
It's just the way it is, my IX MR did it, my X GSR does it; its just the way it is, be easy goin into 2nd and 3rd til she warms up a bit and you'll be good.
Old May 14, 2010 | 12:37 PM
atombomb33's Avatar
EvoM Community Team
Please search. That's all we ask of members. This topic has been discussed at length and a simple search would have found all that you could have ever asked for on this topic. Such as this thread that has 43 pages and is a sticky at the top of the page.
https://www.evolutionm.net/forums/ev...on-thread.html
closed
KillaYayo
Aug 31, 2016 07:31 PM
jamsterjam
Lancer Troubleshooting
23
Mar 2, 2015 08:15 AM
DarkEvo
Jun 9, 2012 08:23 AM
evoinit
15
Oct 30, 2004 07:31 PM
tunaman
Mar 6, 2004 10:44 PM
