Sponsored by:
Sponsored by: CARiD
EVO X Seats Staple Issue Fix
Old May 23, 2010 | 05:24 PM
NJSTI's Avatar
So you guys just take the harness plastic off and stitch the fabric together? You get rid of the staples all completely?
Old May 23, 2010 | 06:20 PM
gizmotoy's Avatar
I'm curious about this as well. Any pictures? I'd be concerned the thread would just tear through the fabric? How much room did you guys leave between your thread hole and the edge of the fabric?
Old May 23, 2010 | 06:23 PM
Methodical4u's Avatar
I don't have the staple issue, but it would make me nervous with the airbag being there that it might not work properly if I tried to fix it.
I would love to just get a nice set of leather MR seats... they are supposedly MUCH better and I can just plug them in and the airbags and such will work just fine... right?
Old May 24, 2010 | 05:46 PM
NJSTI's Avatar
giz raises a good point. Did anybody that stitched the fabric together notice any longterm issues?
Old May 24, 2010 | 05:58 PM
bluegsr's Avatar
hmm im gonna take my staples out and see if that works, ill get back to ya'll
Old May 25, 2010 | 09:28 AM
JMSxCZ4A's Avatar
I've been wanting to fix mine for a while, and didn't want to spend trying to get it repaired by the dealer. Thanks for the repair tips!
Old May 25, 2010 | 11:27 AM
XBoost's Avatar
Originally Posted by woodyqb
No reason to pay for it I did mine in less than an hour. All you have to do is pull the plastic covers off by pulling the front and back halfs apart at the seam. Then just loop some black thread from the front to the back several times pulling it tight and tie it off. I don't know how to sew or tie knots but it was simple. I would not pay to have this done.
Best solution IMO
Old May 25, 2010 | 11:52 AM
NJSTI's Avatar
Originally Posted by XBoost
Best solution IMO
..but will it last? Will it eventually rip the fabric?
I question this solution as being a good longterm one.
Old May 25, 2010 | 02:32 PM
andrewtf's Avatar
It's more likely to rip the foam than the fabric. I stitched mine together and the foam cuts like butter with any type of thread. But still that was maybe 20k miles ago, and I havent had any problems since.
Old May 25, 2010 | 02:49 PM
NJSTI's Avatar
If the only issue with stitching is possible the threads cutting into the foam (makes sense), then I will just put something under the threads to not allow it to touch the foam. Think this would work? Keep in mind, I haven't taken the harness plastic off to see exactly what I am dealing with.
Old May 25, 2010 | 04:33 PM
NJSTI's Avatar
Fixed.
After further inspection with the plastic harness off, I found the fabric would be strong enough to hold up to stitching, so I gave it a go. The results were much better than I expected, the stitching is tight enough to hold up against to the downward pressure that would normally pull the fabric down.
Below are the pics (crappy iPhone pics) from different angles showing how I went about stitching, mainly from front to back. The main trouble area was in pic 4 on the right most side. This area would constantly be exposed with even the smallest amount of pressure, but not anymore. I tested it a few times, and it held up great. I also left the staples in for added security, but they aren't needed with the stitches. The last pic just shows the finished product with nothing exposed. I may stitch the other side of that seat, and then the drivers seat if I notice a problem in the future. Glad I got this resolved, it was bugging the hell out of me.
If anyone in the NJ/NY area has this issue, and needs a hand, I could help you out.
Attached Thumbnails EVO X Seats Staple Issue Fix-seat_fix_1.jpg   EVO X Seats Staple Issue Fix-seat_fix_2.jpg   EVO X Seats Staple Issue Fix-seat_fix_3.jpg   EVO X Seats Staple Issue Fix-seat_fix_4.jpg   EVO X Seats Staple Issue Fix-seat_fix_5.jpg
Old May 25, 2010 | 06:20 PM
CaptainAsia's Avatar
Do the 2010 Evos have this problem too?
Old May 25, 2010 | 07:55 PM
NJSTI's Avatar
Don't know the answer to that, I asked that same question, which I am curious about. My seats were from 08, but I am going to assume other model years were impacted too.
Maybe a list should be started.
08 - staple issue
Old May 25, 2010 | 07:57 PM
dboz's Avatar
Fixed.
How hard is it to get the plastic pieces off. Did you need to stick anything in the crack to pry or did you just pull?
Old May 25, 2010 | 07:58 PM
dboz's Avatar
I would think that RECARO now knows of the issue and either added more material or added a better adhesion. This was a pretty common problem and I am certain that RECARO does not want to lose the MITSU account for supplying seats. I would not worry at all about the '10 seats.
