Narrowed down list for intake and turbo-back, but still can't decide.
I mean get the AMS DP, HFC and catback of your choice (ETS looks nice) and run the Cobb Stage 2. Period. Nothing else.
If you have E85 readily available, add a Walbro fuel pump and DW800CC injectors, then run the Cobb Stg2 E85 map.
You will have a ton of power and torque and zero headaches.
One of the reasons I wanted the AMS or ETS over the AEM was because I wanted to hear the intake sounds (mainly the bov). Now I am reading that I won't get that with the MR, which makes sense. What sounds would I hear with the open element over the boxed AEM?
Every intake that was mentioned by the OP disturbes the fuel trims EXCEPT the INJEN. It is the best intake for the Evo 10. It is the ONLY intake that you can install without a tune. All others require a tune to correct the screwed up trims that the intake causes.
GET THE INJEN
Read more here.
http://www.socalevo.net/index.php?op...&topic=83379.0
GET THE INJEN
Read more here.
GET THE INJEN
Read more here.
GET THE INJEN
Read more here.
ALTHOUGH you should get some kind of tune with EVERY intake.
