mbc on stock vehicle?
going to install a mbc on my stock vehicle and as i read the instructions it says i need a intake and performance exhaust .. am i ok if i install it on a stock vehicle?
NO! Don't dare touch the boost level without tuning it unless you want to potentially ruin your car.
You can install a MBC and get tuned without any modifications however, you will not gain much.
Here, read this.. https://www.evolutionm.net/forums/ev...g-dummies.html
FWIW, my car came used with just a fmic, drop in, catback and MBC set to 22psi. Never really had a problem for 2k miles, but after much research I decided to go back to the stock boost control. Then, I flashed a Cobb Stage 2 map and it works perfectly. Pulls alot better than the stock map with MBC.
You will have to tune anyways (eventually) with an MBC. For no price difference, pick yourself up a 3 port and tune with that. The ECU is more than capable of controlling boost. FWIW, i was tuned using an MBC last year. This summer i am switching over to a 3 port and going back to ECU based control with a retune.
I tried both on my IX, it's no question in my mind for the X.
