Sponsored by:
Sponsored by: CARiD
Project DP complete
Old Jul 5, 2010 | 04:27 PM
BEISSEN's Avatar
Project DP complete
I must say the X's DP/o2 combo from AMS is a pita but not so bad once you get done. I just finished with my Buddys X GSR SSS installing his AMS 3" DP with o2 eliminator kit. I loved the Design it was very well done and now we are waiting on his exhaust to come in. You can hear the turbo spool real nice. If anyone need help on the AMS Kit you can PM me.
Old Jul 5, 2010 | 07:51 PM
lockwood31's Avatar
how long did it take/any big hang ups
Old Jul 6, 2010 | 07:22 AM
BEISSEN's Avatar
Took me from start to finish about 8 hours. But we had lunch and had the car cool off first and a trip to the store to get a tool I needed which was a 1/2 swivel socket. The biggest hand up is the heat sheild/s on the bottom. There is one that had 3 10mm bolts that if you take off you can access the 12mm bolt that is needed to get off to access the final Nut. There are 5 bolts and one nut. The lower heat sheilds have to come off to access the final nut. The on reinstall there is a Black braket that also bolts to the DP that has to be losened which is a 14mm and then you can install the AMS Kit very smoothly. I used the following tools...
3/8 swivel Socket & Breaker Bar & Ratchet
1/2 Swivel Socket & Breaker Bar & Ratchet
3/8 Shallow and Deep Well sockets"12mm-14mm"
1/2 Shallow and Deep Well Sockets "12mm-14mm"
14mm Box Wrench & 14mm Ratcheing Box Wrench
12mm Box Wrench & Ratcheting Box Wrench
And the best helper PB BLASTER FTMFW.
Here is a Tip for the 12mm bolts on the heat sheild on the bottom use a 12mm Box for one and be ready to use some elbow grease. The second one which is hard to get to with out taking the other heat sheild that consists of 3 10mm bolts use a pipe or a short bar that can go on the back of a 3/8 Ratchet with a shallow 12mm socket and it will help alot more.
Old Jul 7, 2010 | 02:55 AM
gripbox's Avatar
glad you got that mod done...from what im hearing, it'll always be a PITA when getting it in there....i guess im looking forward to that soon
Old Jul 7, 2010 | 08:39 AM
BEISSEN's Avatar
Don't stress to much, If you take your time and also use alot I mean alot of PB Blaster not WD40 there is a major differance between the two you will be fine. I will try to get the heat sheilds from my friend and take pictures so you can see what to take off and it will make life easier for you. Also MAP has a decent write up as well with some photos.
Old Jul 7, 2010 | 04:17 PM
Maverickvf84's Avatar
I have the AMS DP/O2 eliminator sitting in the box in my room since april...Im waitin for my wheels to get here and next week im takin all of that plus my tail lamps,AMS FMIC to get installed at CBRD.I already have the AMS Intake / UICP-LICP.I hear the turbo spoil now + blowoff...will I hear it more with the AMS DP?
Old Jul 7, 2010 | 04:27 PM
BEISSEN's Avatar
That stuff is easy to install on your own but I love working on cars. But a farfar as parts the intake will let the Turbo sound be more noticeable. But the ams o2/dp makes the power come smoother.
Old Jul 8, 2010 | 03:20 PM
sweet!thanks...i would love 2do it myself but i think ill let the pros handle this
Old Jul 8, 2010 | 08:23 PM
BEISSEN's Avatar
Are you going to have them tune it when your there? With the added airflow its really needed.
Old Jul 9, 2010 | 06:38 AM
Most definetly!1 thing I learned coming from a civic is that the ECU is the main key for unlocking all the potential power of any car!
cij911
139
Mar 19, 2021 04:19 AM
BaumBizzle
Jun 1, 2012 09:01 PM
Evol X
Jun 17, 2010 07:18 AM
morfhious3
12
Aug 3, 2009 05:59 PM
PPI
Sep 29, 2008 06:06 AM
