Sponsored by:
Sponsored by: CARiD
Clutch?
Old Aug 29, 2010 | 06:09 PM
nefarious_Saint's Avatar
Clutch?
Ok so i picked up my GSR last night. This is my first manual car. My question is this, when starting to drive from a complete stop, some say to try and and not go above 1500 rpm in first gear to start off. Will i really cause soo much damage if i let it slip a little at 2500-3000 rpm just to get it moving? I really dont want to stall and figure that its better to slightly wear the clutch then to have a violent stall in a brand new engine. Thanks for your input guys.
Old Aug 29, 2010 | 06:28 PM
chaotichoax's Avatar
2500-3000 rpm is a lot...this car is very easy to ease away at from 1500 rpm...if you continue to ease away at 3k rpm you'll be eating up your clutch pretty quickly
you'll only get better with practice but you'll be paying in the long run for picking a car with an expensive clutch servicing
Old Aug 29, 2010 | 06:29 PM
GiLizILL's Avatar
the only time I come close to 3k rpm is on a step hill. it is my first manual too
Old Aug 29, 2010 | 06:32 PM
Segfault's Avatar
Yeah, it'll just kill your clutch early. However, note that on some of the more heavy duty clutches you will be rev'ing higher.
Old Aug 29, 2010 | 06:44 PM
laxplayer14's Avatar
just know the general area to where the car starts moving when you lift of the clutch, however itll change due to the restrictor pill, for now just know where it is generally. the way to save your clutch is to use as little gas to get the car moving. itll take a little more gas since it is an awd car thats pretty heavy, and even more gas on inclines. but you should never be revving past 1.8-2k to get your car moving, i personally try to rev below 1.5 to save my clutch. so yea just steadily lift off the clutch and give it gas and you should be good, but keep it below 2k dude, good luck man
Old Aug 29, 2010 | 07:01 PM
ToddMcF2002's Avatar
I did a very minor launch at 3K yesterday. It was fun but smelly. That's gonna cost me down the road. I want to preserve the stocker at least until SSP and Magnus get their sh*t together.
Old Aug 30, 2010 | 12:52 AM
Thanks everyone for giving awesome advice. The car has only 48 miles on it ( i got it new yesterday with only 5 miles) and i stalled only once. However, i figure to break in a new engine, stalling all the time will do more harm than revving to high to get it moving.
Old Aug 30, 2010 | 01:04 AM
EndlessRed's Avatar
putting into consideration that it's your first manual, my recommendation is that you should start at around 2-2.5k, and work your way down. it's better to do it that way than risk stalling time after time, and still not being able to figure out where the engagement point is. at least with this method you can feel where the clutch engages, and as you drive more, you'll be able to lower that rpm.
although i have to say that using an evo for your first manual may not be the best choice ever. the clutch is very unforgiving when it comes to abuse, whereas low powered cars can take a beating, just because it can't dish out that much hurt anyway.
Old Aug 30, 2010 | 09:17 PM
tehSteve's Avatar
I started @ 3k cause it was my first manual I owned too. Totally abused the clutch for a good 600+ miles. You'll get the hang of it. I'm down to 2k moving and about 2.5 on steep hills.
The way I think of it is if the clutch goes who cares bro... you learned on an AWD sports car. sup?
Old Aug 31, 2010 | 12:13 AM
MAX EVO's Avatar
Congrats getting the EVO.
The EVO has great torque so you don't have to worry to much about launching the car from a stop unless your at an incline.
Here's tip my dad told me when I first started to drive manual cars.
Go to a parking lot that is flat, or if you have a long enough driveway at home.
Put the car in first gear let go of the brakes but keep the clutch pedal down. Do not touch the gas pedal. Slowly start letting the clutch pedal up. At this point you should be able to launch the car with out use of the accelerator. Obviously this is to help you to time when to put down the gas. Take it nice and slow and get the feel for your EVO. Once you get that feel starting on hills will be a bit easier.
Sorry to ramble on, but this technique really helped me out give it a try. Remember to take it easy and slow. In no time you'll feel likeyou've been driving manual forever.
Congrats again.
Old Aug 31, 2010 | 01:51 AM
Thanks everyone for your constructive advice. Been learning on a parking lot all night tonight. Its frustrating, but im getting better.
Old Aug 31, 2010 | 10:35 AM
Congrats again.
couldnt have said it any better when learning to drive stick, finding the engagement point is key!
Old Aug 31, 2010 | 11:35 PM
MAX EVO's Avatar
I forgot mention putting the car in reverse will also help you to find that engagement point.
Old Sep 1, 2010 | 06:43 AM
derekste's Avatar
1- mash gas to engage stationary rev limiter (5500 rpm)
2- slip clutch like a ****
3- ????
4- Profit!
Old Sep 1, 2010 | 10:07 AM
raytrix's Avatar
900 rpm take offs is the way I go.
