Sponsored by:
Sponsored by: CARiD
New owner! With a question.
Old Oct 28, 2010 | 01:12 PM
FloopyDisk's Avatar
I'm the new owner of a 08 GG X. It's lowered by springs (not sure which ones) has an intake in it. SSS, Aero, and Navi. Had to turn in my 8 though =(. Anyways, of course after I buy it I notice only some times under acceleration between 3k+ to redline it'll drop by a few hundred RPMs after a little bit. For example 3k-4k, it'll reach 4k then it'll go back down to 3.8k and then keep accelerating. I know the 08s had some issues with the ECU and a lot of flashes were given by the dealer. Is this the flash, is this normal, or is the clutch slipping?
Old Oct 29, 2010 | 01:38 PM
FloopyDisk's Avatar
Bump.
Old Oct 29, 2010 | 07:02 PM
Segfault's Avatar
I've never heard of that to be honest. It won't hurt to take it back for the latest and greatest ECU update.
Have you tried going to the bottom of 4th and going WOT? If your rpms shoot up all the sudden and come back down before accelerating than it's most likely your clutch.
Old Oct 29, 2010 | 09:35 PM
3BEEPS's Avatar
your clutch is slipping
Old Oct 29, 2010 | 09:39 PM
erald01's Avatar
clutch slippin is easy to notice, try going at wot in any gear and if the rpm is jumping but the car is not moving then the clutch is done...didnt you check the car before buying it???
Old Oct 29, 2010 | 09:42 PM
healthynine's Avatar
easiest way to check the clutch...
Drive around a bit to warm up the car and clutch. Put the car in 5th at about 35 to 40mph. Floor it. Obviously you are in too high of a gear, but you'll be able to tell if the clutch is bad because the RPMs will jump really fast.
Old Oct 30, 2010 | 11:09 AM
FloopyDisk's Avatar
I did. I drove around and put it in WOT in 3rd and it didn't do it. Kind of weird. It didn't do until I left and had bought it.
I will check a few of these steps. Thanks guys.
Old Oct 30, 2010 | 03:14 PM
EvoG8r's Avatar
Could be input shaft seal leak. If it leaks it will make your clutch slip. Happened to me and was replaced under warranty.
Old Oct 30, 2010 | 04:10 PM
KJ82's Avatar
Your clutch might be going bye bye.
Old Oct 30, 2010 | 04:20 PM
linjy2's Avatar
probably not what you are describing but when i had my X new it had a power dip around 4-5krpm. or something like that, cant remember.
it would pull hard to 4krpm then lose momentum till 5k and starts pulling again.
a tune fixed that for me though
Old Nov 2, 2010 | 01:11 PM
Shig's Avatar
my mr does something like that while idling. the rpm moves up and down. but idk about while driving. never had that issue
Old Nov 2, 2010 | 01:16 PM
journeymansteve's Avatar
There's a TSB for the 2008 for intermittent high idle miss. It should be covered under the 5/60 warranty according to my stealership.
Old Nov 2, 2010 | 02:09 PM
FloopyDisk's Avatar
Just got a call from them. They said it's the clutch that just started going. They did offer to cover half the cost of the service and parts though.
Old Nov 2, 2010 | 02:17 PM
ClaudioEvoX's Avatar
that is happening to me right now and it all started after Englishtown event.... oct 23 .... thats the clutch.... sorry to say but the evo x came with alot of good components to race but not the clutch...
act.. coming soon
Old Nov 2, 2010 | 05:42 PM
Segfault's Avatar
Depending how much half the cost is, it might be better to just take it to a shop and get a better clutch installed.
