Sponsored by:
Sponsored by: CARiD
valve stem leak
Old Feb 7, 2011 | 03:34 PM
turbo125's Avatar
valve stem leak
So I had the low tire pressure light come on for the first time. Filled it with air and two days later it was on again. I took it to the tire shop thinking i might have got a nail in it, turned out the valve stem was the reason for this leak. They took out the tpms and put a rubber one in for now. Mitsubishi doesn't warranty a bad valve stem and they only sell the whole system, not the valve stem separately and I don't want to buy a new tpms and pay them to install it. The valve stem is separate and can be removed from the system but I haven't been able to find anywhere where I can just buy the stem and replace it. Does anyone know where they sell rebuild kits or parts for these systems?
Thank you
Old Feb 7, 2011 | 03:39 PM
revvin9k's Avatar
Thank you
Do you have the stem in you hand? The TPMS sensor has a small rubber grommet at the base that needs to be replaced. It seals the wheel when the sensor is tightened down.
PM me your addy and i'll send you two kits for free. Just put the lil rubber boot that comes in the bag I send you on your sensor.
Obviously take the old one off first.
EDIT: make sure your stem is not cracked. Metal valve caps tend to oxidize with the stem and get fused together. If you try too hard to remove the cap.....snap.
Old Feb 7, 2011 | 03:41 PM
ugakirk's Avatar
They sell a rebuild kit for all tpms valve stems. I can't believe they didn't know anything about that. It's should be "rebuilt" everytime you replace the tire. I would call a good tire shop and ask them. It comes with a couple rubber oring, a replacement valve, and a new cap. They're pretty cheap too.
Old Feb 7, 2011 | 08:42 PM
turbo125's Avatar
revvin9k thank you for your generosity to send me the kits for free. Tomorrow im gonna call the tire shop and Mitsubishi and see if they have the rebuild kits and see if it works. Thanks for all the help, much appreciated!
EVLX
Nov 21, 2015 10:23 PM
wicked white14
Mar 28, 2013 10:40 AM
R Lar
May 22, 2012 08:03 PM
Magik
Oct 28, 2011 03:57 PM
brads09lancerGT
10
May 27, 2011 01:21 PM
