Sponsored by:
Sponsored by: CARiD
First post first question !
Old Mar 1, 2011 | 09:17 PM
Fittest's Avatar
Big difference in driving experience between this car and you STI (both good and bad). The notchy transmission and "rev hang" on the RPMs are two of the negatives. Crazy handling and whp mod for mod are two of the positives.
Old Mar 2, 2011 | 06:51 AM
kzlflash's Avatar
My Notch didn't really go away when I shift into second until I hit 4.6k miles. Also, I changedmby fluid to redline and bushings and a heavier shift knob to TWM at around 3k and it's barely feeling smooth now. Still notchy sometimes. Just give it some time. But it's something you're going to have to live with if you stick with this car.
Old Mar 3, 2011 | 09:53 AM
fast08's Avatar
Originally Posted by la_laker_fan
Not sure if you've seen this thread yet, but there are 47 pages of information here:
https://www.evolutionm.net/forums/ev...on-thread.html
Thanks, I read through most of it. I started the thread mainly to get some updated feedback since some of those are from 08/09.
Old Mar 3, 2011 | 09:55 AM
fast08's Avatar
I actually don't miss the STI for some reason, it was stage 2 and protuned but just it doesn't feel nimble. I noticed the rev hang on the X too, but not too bother by it..
Old Mar 3, 2011 | 10:10 AM
nvisan's Avatar
Not sure what to say about first gear bought mine with 15k miles on it and never had a issue. Reverse doesn't have a dedicated gear its a mesh of 1st and 3rd to get reverse that's why you're having the lockout issue there. For reverse just roll the car forward a bit, whether in neutral or 1st and reverse should pop right in.
Old Mar 3, 2011 | 11:30 AM
oftheheavens's Avatar
i changed my bushings (shift and underhood) at like 500 miles, along with the redline fluid. Felt like i was shifting the old "cruisin the usa" arcade shifter. Smooth fast and straight into the gears.
recently, I assume because it is cold, i have been getting some of the 1st and reverse jams. Double clutch and back on my way. I am about to replace the redline with amsoil GL4 though, just because.
Old Mar 3, 2011 | 08:48 PM
alex3dworld's Avatar
Evo X is an S&M girl
leave it under the sun at 120 degrees for four hours and everything is going to work perfect shifting gears
treat her like a princess and she will refuse all the time
treat her bad!!!!!!!!!!
Old Mar 4, 2011 | 03:32 AM
Get Rad's Avatar
HAHA
Old Mar 4, 2011 | 05:15 AM
KJ82's Avatar
Though my shifter was just a tad bit notchy(bearly noticeable) I bought under the hood shifter bushings and all gears slide ride in like a wet chocha...!
Old Mar 4, 2011 | 05:46 AM
ugakirk's Avatar
Just push the clutch a few times.
thadon84
38
Aug 23, 2016 12:35 PM
MarkChamorro
Jul 14, 2012 10:20 PM
awdwannabe
Dec 17, 2008 01:14 AM
Jrod@Buschur
May 19, 2008 09:12 AM
Nineball
34
Oct 20, 2007 10:49 AM
