Sponsored by:
Sponsored by: CARiD
Anorexic Evo...
Old Apr 25, 2011 | 04:07 PM
Renley's Avatar
Anorexic Evo...
Ok, so I am looking to improve my braking and cornering ability on the track. While good coilovers did a lot, i still feel the car handles too "heavy".
So I wanted to start doing some weight reduction.
However, this is my DD so i cant go nuts like removing seats or spare tires and air bags.
So I was hoping to tap into the knowledge base here of all the people who know of simple and effective things i can remove on the X to lose weight.
Here are some items i have been considering (so feel free to offer a sanity check or opinion on any of them)
- Replace stock front seats with carbon fiber lightweight racing seats (there appears to be a few out there that are livable for DD)
- Replace rear doors with Seibon carbon fiber doors
- Remove AC and related components (i live in Colorado so AC is not a must...)
- Remove sound deadening material from firewall inside car and (if any) front doors
- more??
what do you think guys?
Can i drop 250lbs without doing something crazy?
Old Apr 25, 2011 | 04:21 PM
Kryx's Avatar
Replace the stock exhaust? You can save easily 20+ lbs doing that.
Old Apr 25, 2011 | 04:36 PM
Get Rad's Avatar
There is an entire thread on this. Do a search.
Old Apr 25, 2011 | 05:18 PM
sfearl1's Avatar
Remove fog lights. Swap hids to lamps.
Old Apr 25, 2011 | 05:38 PM
Evod350z's Avatar
Do the driver mod to loose weight.
Old Apr 25, 2011 | 07:11 PM
anEVOx's Avatar
Haha. I lost 40 lbs off my gut. That should help a little eh?
Old Apr 25, 2011 | 07:16 PM
blk-majik's Avatar
you can lose about 40lbs and imrpove braking with a lighter brake kit. most of that is rotating mass as it comes from the rotors
Old Apr 25, 2011 | 07:22 PM
Get Rad's Avatar
Since no one else is going to do this
https://www.evolutionm.net/forums/ev...on-thread.html
Have a blast buddy and there is a link to another thread in this thread as well
Old Apr 26, 2011 | 03:00 AM
Johnr352's Avatar
Weight savings can make a big difference but I would suggest you focus on getting the car's handling set up for the track. Coilovers are a good start but sway bars and and bushings (ROCK) etc will go a long way to reduce that heavy feel in the corners. And, of course, the biggest impact to your handling, is tires. R compounds, good ones anyway, will make a tremendous difference in the on track agility of the car.
For weight savings, concentrate on unsprung first. Lighter wheels, tires, rotors and calipers will have a greater affect on the car then swapping your doors. Read the threads, but concentrate on getting the car set up properly for the track and then focus on tweaking for weight savings.
Old Apr 26, 2011 | 01:40 PM
Renley's Avatar
Thanks for the info guys!
I actually searched for that thread and it didnt come up :P so thanks for the link too.
Old Apr 26, 2011 | 04:22 PM
Get Rad's Avatar
Google can work wonders
Old Apr 26, 2011 | 04:29 PM
ImEv0's Avatar
this. reducing rotational mass is the best kind of weight reduction.
Old Apr 26, 2011 | 04:37 PM
Get Rad's Avatar
Rotational or Unsprung weight
Old Apr 26, 2011 | 04:58 PM
evokerfes's Avatar
Get light weight wheels. Get light weight rotors.
Old Apr 29, 2011 | 02:09 PM
Wrex1977's Avatar
fill the trunk with helium...
