Sponsored by:
Sponsored by: CARiD
Evo X MPG
Old Jul 28, 2011 | 07:20 PM
  #121
jazket's Avatar
Originally Posted by Q15H
Not sure what you're tying toi say here. Are those boosted engines? Did not see any indication of same on that page.
BTW - My eleven-year-old design prius uses a static 13:1 CR and recommends 87 octane. Not too many boosted or direct injection engines that run that high.
yeah their 2.0l turbo based on the global design has a Mitsu turbine in it for the Sonata 2.0T Limited, 270hp and it does 22 city, 36 city, 26 comb.
It's nowhere near an Evo but it does have a turbo lol and it's north of 200hp too
Old Jul 28, 2011 | 09:29 PM
  #122
victorlg88's Avatar
thats not so bad my regular lancer gets 20 in the city
Old Jul 29, 2011 | 02:43 AM
  #123
formerRX8owner's Avatar
Cool RX8 was way worse..
Be glad your getting in the 20's... both my RX8's never saw 20...best I ever got was 17.70 mpg....usually got 16 most of the time even if I babied it. 20's is hybrid #s in the sports car realm.
Old Jul 29, 2011 | 08:38 AM
  #124
Q15H's Avatar
I thought RX8's were measured in quarts [of oil] per tank also??
Old Jul 30, 2011 | 06:30 AM
  #125
acidtonic's Avatar
Originally Posted by FCDRIFT
The new rotary will be better (supposedly)
What annoys me about the rotary is that it's actually not bad design at all. A proper rotary can make awesome power, but those are unobtainium and Mazda only gives the public a weak anemic motor.
I would love a smooth 500hp 3 rotor, but good luck piecing that build together let alone affording it.
Old Jul 30, 2011 | 10:04 AM
  #126
Ladogaboy's Avatar
Just a little nit picking here and there.
This, is false:
Originally Posted by acidtonic
Then I shift to 5th and just gently maintain speed and coast clutch out to red lights so I cut fuel.
You are actually better off leaving the car in gear and compression breaking. Modern cars actually cut fuel to the engine completely under those circumstances. An added benefit is that you save your brakes too!
Also, this is a bit off:
Wing removal helps mileage since by design, the wing provides resistance which turns into downforce.
The downforce itself is not the culprit here, it is the drag. Most high-efficiency cars have a spoiler or airfoil of some sort in order to create downforce, though they tend to be of a low-drag design. Once you hit highway speeds, the "weight" of your car (including downforce) becomes a less significant factor than the drag, and ironically, the downforce at those speeds actually increases efficiency by preventing the rear of the car from becoming unstable.
Old Jul 30, 2011 | 10:14 AM
  #127
Ladogaboy's Avatar
I think that the biggest problem with rotary engines is the reliability. Even the best rotary engines have a maximum lifespan of 70-100k.
Old Jul 30, 2011 | 11:39 AM
  #128
Q15H's Avatar
That's what Mazda has been saying for three+ decades now. True, each new "design" get better, but they're still no where near the reliability or long life of a piston-valve engine.
Where the rotary design is superior is in HP vs weight. Unfortunately they're classified, and rightly so, like a 2-cycle engine as they have twice the power strokes per crank rev as a normal 4-cycle engine so the weight isn't necessarily and advantage in racing rules. Although you do get to choose where to add your ballast.
And in my experience with rotary engines over the last 35 years - they suck fuel no matter what power level one is using. Never seen one get good fuel consumption figures.
And if you've ever been around one on-track with open pipes - DAYUM! Those things are annoyingly loud and just make an ugly, ugly noise.
Old Jul 30, 2011 | 12:57 PM
  #129
Ladogaboy's Avatar
This is the future of rotary engines:
http://www.uqm.com/powerphase%20hd%20select%20200.html
Old Jul 30, 2011 | 04:50 PM
  #130
Q15H's Avatar
Actually those are called motors.
Old Jul 30, 2011 | 06:58 PM
  #131
Ladogaboy's Avatar
*tap* *tap* Is this thing on?
I was being facetious.
Old Jul 30, 2011 | 08:47 PM
  #132
Q15H's Avatar
"Can you hear me in the back??"
Yeah, I kinda got that. No worries.
Old Jul 30, 2011 | 09:33 PM
  #133
Ladogaboy's Avatar
I must have been in the.... DEAD ZONE.
Old Jul 31, 2011 | 11:27 AM
  #134
Q15H's Avatar
I think people were talking in the back.
Old Jul 31, 2011 | 11:33 AM
  #135
guswaym's Avatar
im stage 2 and i get 26 mind you my foot is made out of jello
