Sponsored by:
Sponsored by: CARiD
Vibrations at idle....
Old May 2, 2011 | 06:43 AM
flagg77's Avatar
Sounds like motor mounts to me.... check them, if they're anything other then block rubber, you have after market, higher durometer motor mounts. Those will transmit much more vibration into the car.
Old May 2, 2011 | 08:46 AM
samshowerman's Avatar
Originally Posted by ugakirk
I would find the cause. You would only be hiding the problem. Go to a good shop that knows Evos. It could be just a mod that you don't know about..
Ahhhh F**k that's what I was hoping not to do... but idk what it could be though that would have it idle so low..because im pretty sure there is no form of tune or ecu mod... a stage 2 or 3 clutch wouldnt cause this wwould it?
Old May 2, 2011 | 08:55 AM
ugakirk's Avatar
Yea thats what I'm thinking. Just look at all the mounts. If they are red or pretty much anything other than black, there is your answer..
Old May 2, 2011 | 08:57 AM
ugakirk's Avatar
Well, think about it.. If the car is in neutral and idling, is the clutch doing any work that would make a vibration?
It REALLY sounds like motor mounts..
Look at the AMS description of their motor mounts..
The AMS Polyurethane Transmission Side Motor Mount will decrease transmission movement and result in more precise shifts and improved throttle response. This piece has a Durometer rating of 70A which will transmit less vibration through the cabin than other popular brands which use a harder polyurethane.
Features
Improves shifting and throttle response
Decreases Motor and transmission movement which in turn improves shifting and drivability.
Kit Includes
Motor Mount with Polyurethane Insert
Center Bushing
Specifications
Polyurethane Bushing Inserts
70A Durometer rating
Zinc plated center bushing
Applications
Mitsubishi Evolution 10 GSR & MR Models
Fits all USDM, JDM and European Models
Please Note:
Use of this mount will transmit more engine vibration into the passenger compartment
Old May 2, 2011 | 09:36 AM
KSIceman's Avatar
I also have a rough idle, and my car is completely stock. I'm yet to check the hose problem yet though, so mine's not an applicable case. That, and I would dare say the WHOLE car is shaking...just a rough idle at times.
I'd be hard pressed to say your motor mounts are failing so soon, but hey, maybe it's a lemon. Are you on warranty still?
Old May 2, 2011 | 01:35 PM
Features
Kit Includes
Center Bushing
Specifications
Applications
Please Note:
Just checked all the mounts.....they are all stock with the japanese characters and all...i'm completely baffled by this. Its not the motor mounts, not the hose, its not a lemon i know that. They thing runs perfectly fine in motion and there is no noise being emitted from the engine compartment (besides the clutch engagement) The only thing i can think of is a bad tune or something like that? anything else that it could be??
Old May 2, 2011 | 02:32 PM
toshibakoludo's Avatar
Check your spark plugs and lines.
Old May 2, 2011 | 03:45 PM
The cars only got 12 thousand miles...but ill check the plugs all the same. and the lines are all good. I checked damn near everything. thanks for the plug recommendation though!
Old May 2, 2011 | 04:41 PM
migs647's Avatar
Yah was gonna recommend plugs next.
Only other thing I can think of is some sort of vacuum leak.
Old May 2, 2011 | 05:09 PM
Optiblue's Avatar
Try a better brand of oil if you're using Mobil 1. After I switched to total, it's butter smooth now
Old May 2, 2011 | 05:11 PM
migs647's Avatar
There is NO WAY oil is doing what the OP is describing. Mobil 1 should be just fine for his car.
It's definitely mechanical / electrical from his description.
Is it possible to get the car on a lift while running? Use a stethoscope to pinpoint the noise area. That may help us figure out what is causing it.
Also can you give us snapshots of your engine bay?
Old May 2, 2011 | 05:24 PM
whtrice's Avatar
Veteran: Air Force
Does the exhaust sound lopey at idle or smooth?
Old May 2, 2011 | 06:47 PM
one of my buddies lift will be open as soon as he takes his mustang off it. but yeah its def. not the oil. its something mechanical im pretty sure....im just not sure where to begin with the stethoscope. and yes i can do some pics. any specific areas in the engine bay that would help the most??
Old May 2, 2011 | 06:48 PM
The exhaust does spit at the rear of the car. It just sounds like its dying for air.
Old May 2, 2011 | 10:38 PM
Evostare's Avatar
Would like to know whats causing this, keep us posted with what you find.
