Vibrations at idle....
Hey guys,
So i just recently purchased myy 2010 evo and was wondering if you guys have any vibrations at idle...the only mods i know for sure that are on the car are an MAP downpipe, ETS exhaust, intercooler piping, and intake. Would the vibrations be from a bad tune or lack of tune? Just wondering if its something serious that should be looked at or if its minor...
Hey guys,
Vibrations at idle wouldn't have anything to do with a tune unless the car can't idle correctly. Do you mean vibrations inside the car? Under the hood? Closer to the rear of the car?
Could be a heat shield, a loose bolt, a missing tab or something..
No its not like a bolt or heat shield that is loose...it vibrates the hell out of me in the drivers seat and the car just shakes...would it be the motor mounts or something?
Did you also check the hose that comes off unless zip-tied/secured?
https://www.evolutionm.net/forums/ev...s-do-asap.html
I think its hilarious how every time anything happens people say check the hose..
If it has aftermarket motor mounts than it would def do that. And +1 on maybe a low idle. How does the car "feel" and sound at idle? And what ETS exhaust is it? Maybe the exhaust is sooo loud, and that's what you feel..?
What hose are you guys regering to? But regaurdless, I don't think it has anything to do with pressure because i tried giving it some gas to idle at like 1100 rpm and the shaking stopped....so would I just have to adjust the idle? I was just wondering why it would shake at the stock 750 rpm....
Alright so I checked the howse that u all are referring to...and its on there nice and tight..so its not that...would it just be theat its idling too low and needs to be raised?
