Sponsored by:
Sponsored by: CARiD
Stock fuel pump and overall performance question.
Old Jun 13, 2011 | 02:22 PM
Bizzlex's Avatar
Hey guys. I was wondering, what is the size of the stock fuel pump on a 2010 evo x and at what horsepower (At the crank or flywheel) will i need to start reinforcing the motor and get a new fuel pump and injectors.
Thanks a lot!
Old Jun 13, 2011 | 02:26 PM
Kracka's Avatar
My stock pump was able to support basic bolt-ons with the stock turbo on pump gas, but when I added the ported manifolds and TB I had to go with a Walbro. The line was in the ~345-350whp area on Cobb Plano's Mustang dyno.
Old Jun 14, 2011 | 08:05 PM
Bizzlex's Avatar
ok so with my next mod i will need to upgrade my fuel pump. What about injectors and the motor itself. I know its not a 4g63, but the A4b11t has proven itself quite reliable. So im wondering when i will have to worry about upgrading other things. Thank you very much i apreciate your help.
Old Jun 14, 2011 | 08:33 PM
anEVOx's Avatar
What exactly are your plans? If your staying stock turbo and pump gas the stock injectors should be sufficient? If you go E85, injectors and fuel pump are a must.
Old Jun 14, 2011 | 08:43 PM
Bizzlex's Avatar
well i am going to go either FP red FP green or turbonetics turbo, and cams. i dont want to blow my motor tho
Old Jun 15, 2011 | 06:02 AM
Kracka's Avatar
Correct, the only thing I don't have is cams and my stock injectors are still fine on pump gas. I did buy some DW800's just in case though
If you want to keep your stock engine safe my recommendation is to stay with a turbo the size of a FP Green, CBRD BBX Lite, or MAP EF2.
5k6
E85 / Ethanol
Dec 20, 2016 05:13 PM
evoholic3088
Jun 1, 2016 10:29 AM
Tractionlimit
14
Jun 25, 2009 11:34 AM
AWDsub
Nov 17, 2007 01:41 PM
djd24
10
Aug 31, 2006 07:02 AM
