Sponsored by:
Sponsored by: CARiD
Evo X two step
Old Jun 4, 2012 | 11:43 AM
  #76
Snakes709's Avatar
You obviously dont know how to read or disnt understand my post. Note sure how i could make it any more clear.
Old Jun 4, 2012 | 11:48 AM
  #77
Iowa999's Avatar
No, the problem is that you don't seem to know the difference between a two-step and traction control. And I'm too grumpy to explain it.
Old Jun 4, 2012 | 11:52 AM
  #78
Robevo RS's Avatar
Originally Posted by Iowa999
Now I think that you're being too picky, saying that they're not even close when the Y in AYC stands for "yaw."
Think about it this way: which ECU sends the command to the ABS unit to activate single-wheel rear-braking help for yaw?
Really? Are you serious? I didnt know....
He and i am talking about the ayc, which he couldnt even spell right, then he clarifyes him self about it. He talks about turning off the ayc....
I dont even know where i start then here... there is no option to control the only rear brake locks for the abs ecu.... so from there your theory is doomed. And we dont even start.
S-awc controls is the whole system and you can turn off parts of it. You can not turn off the ayc. And you know it.
You can turn of the throttle assist and the abs in the s- awc sytem, that is all you can do... see we are talking about a completely different subject...
So i have no clue what try to accomplis here...
Ayc is an active yaw control, which is a name of the electronically controlled lsd.( limited slip differential)
And that is controlled separatly from the s-awc. You dont have an option to change anything on it. No buttons nothing. Its a single self controlled unit. Exists before the s-awc control. In the older evos.....
All away back to the evo6.
Old Jun 4, 2012 | 12:05 PM
  #79
Iowa999's Avatar
Actually, Rob, not only are you probably right and I should not have defended him at all, but I'm done (for a while, at least) with arguing. When it's clear that someone has no clue at all (see above for a good example, where the throttle-cut TC is being called a two-step), I'll just say it once and walk away. I, especially, don't want to be on the other side of something from you (unless and until we actually disagree on something).
Old Jun 4, 2012 | 12:43 PM
  #80
Snakes709's Avatar
Once again, you obviously cant read. I never said throttle cut or pushing the button once is 2 step. Its retards like you that start fights on the forums because you dont read.
Old Jun 4, 2012 | 12:49 PM
  #81
Robevo RS's Avatar
The rtwo step is speed and clutch controlled. Not traction.
i know you need to change set up for the mr, only because the sst transmission.
I dont think you need to push anything for the manual. Certainly true, for the older evos. Just full stop , clutch in full throttle, and you get a rev bouncing for the launch.
Old Jun 4, 2012 | 01:19 PM
  #82
Iowa999's Avatar
why is this still being discussed? basically the short end of it... press and hold the tc button for 3 seconds. Once it shuts off, you will be in 2 step, launch it and it wont take power away if it detects wheel spin.
bold added
- the retard who can't read
ps. what you really did was turn off the type-1 TC, not turn on the two-step; oh, and you only needed to tap it
Old Jun 4, 2012 | 01:21 PM
  #83
Snakes709's Avatar
For 2 step on the gsr you have to hold the asc button for 3 seconds. Just like in the video above once t chimes you are good to go. The rev limit will go to 5500 and you will build 5psi.
Old Jun 4, 2012 | 01:31 PM
  #84
jeffo24's Avatar
just thought i'd chime in.
Snakes, i have a 2011 gsr as well.
When i tap that button once (not hold it), i get the rev limiter and am able to do the two-step. You are saying that the rev limiter doesn't go into effect with one tap of the button, which isn't true. (at least one mine)
That is all.
Old Jun 4, 2012 | 01:37 PM
  #85
Iowa999's Avatar
Ever tried it with the ASC fully on? How wrong do you think he is?
Edit: you know what's funny? Go back to page 1 of the thread and start at the beginning. The first reply is dead on, the second agrees, and it keeps going fine until about the 7th reply and then it just goes to heck. Maybe they should simply institute a limit on replies and all this nonsense could be avoided. One thing's for sure: that Iowa guy with his semi-rhetorical questions is not helping at all. What a maroon.
Old Jun 4, 2012 | 01:45 PM
  #86
johnys9292's Avatar
learned something new haha
Old Jun 4, 2012 | 02:07 PM
  #87
Robevo RS's Avatar
Old Jun 4, 2012 | 02:16 PM
  #88
Robevo RS's Avatar
I feel a same way, that is why i was wondering what a hell you doing... lol
as you see doesnt really matters what we say, they know better
I always learn from this forum. If nothing else, ay least a human behavior in different circumstanses.
Its like you go to the zoo and throw a banana into a cage and see what happens. Lol
i love evom
Old Jun 4, 2012 | 02:21 PM
  #89
Iowa999's Avatar
If you do the zoo thing, throw a single banana into the Bonobo habitat. You see, unlike a lot of other primates - (note to the Great Unwashed: that includes us) - the typical response of Bonobos to a stressor, such as fewer pieces of food than animals that are hungry, is to start having s3x. I tried this once at the Wild Animal Park in San Diego. The workers knew exactly what I was doing and were not amused. So I went over to the Lowland Gorilla place and started staring directly at the silverback. I was trying to get him to throw his **** at me, but the workers were now following me.
I might still be banned.
Edit: of were you just quoted that post of mine to show how I can't keep a promise for more than an hour?
Old Jun 4, 2012 | 02:22 PM
  #90
Evostare's Avatar
i love evom
LOL! Rob, I'm totally stealing that and using it as my sig. Thank you.
