Sponsored by:
Sponsored by: CARiD
What to do? 2011 Evo X
Old Jul 12, 2011 | 06:47 AM
jazket's Avatar
Originally Posted by slebo3213
I'd get a lawyer. It's a $35k car and I bet a lawyer could get things moving with a few phone calls and/or letters for not more than $1k, probably half of that. At least give a lawyer a call to get some advice.
yeah get advise from a Lawyer but don't just give him your cash unless ultimately necessary... they'd charge an arm and a leg for a simple letter... stuff you can do yourself
Old Jul 12, 2011 | 11:30 AM
Sheyko's Avatar
Thank you very much everybody that replied! That link that includes the Do's and Don'ts helps a lot!
I think I will consult a law firm just see what they think. My girlfriend is actually going to law school next year and was an english major for under grad, so she can likely help write a letter that sounds well versed!
Hopefully I can get this thing replaced and really enjoy the car.
One last question for you guys. As I mentioned, the car was vandalized not too long ago. It still has the dents as I haven't had much time to get the car into a body shop.
Should I hold off in getting it fixed as the car may be getting replaced? Or should I just get it fixed and go forward from there with trying to pursuing the Lemon Law?
Thanks!
Old Jul 12, 2011 | 03:30 PM
jazket's Avatar
Forget about fixing it bro... the car is a Lemon... the issue is the brakes, not the door dings... they can't give you crap for that... they shouldn't give you crap for that
Lemon it ASAP! forget the rest
Old Jul 12, 2011 | 07:18 PM
LOL WUT's Avatar
If the dealer doesn't want to play ball with you tell them to lawyer up and you'll see them in court. If it has truly been in six times for an identical issue it is 100% covered under the lemon law.
Old Jul 13, 2011 | 07:51 AM
Dr1fter's Avatar
100% Agree. 6 times is TOO many repeat visits for the same issue to not be fixed. Time for you to make Lemonade.
Old Jul 13, 2011 | 06:35 PM
spdrcr's Avatar
I've had a 2010 Evo X SE since December and I just started experiencing the 'Brake System Service Required' warning flashing on while driving.
It happens intermittently usually just after start up. I hear a click in the lower left of the dash, the stereo turns off, the tach turns off (goes to 0), then it all returns to normal in a couple of seconds. I still have power and brakes. I haven't taken to the dealer yet because it just started a few days ago and I can't reproduce it nor predict when it happens (which sucks to ask the dealer to diagnose phantom symptoms).
If I find anything out, I'll post it.
Old Jul 13, 2011 | 07:04 PM
Sheyko's Avatar
Very interesting...
Mine is somewhat different. The first start of the day won't produce the warning. Every startup there after however, will. (for the rest of the day that is). My stereo never turns off or anything like that, but it is discouraging.
I hope I can get an Evo that doesn't have problems.
Seems like most of them are good!!!
Old Sep 22, 2011 | 08:00 AM
jeffo24's Avatar
mine just started this problem too, at 4500 miles. Car drives just fine. The light turns on only when i'm accelerating though.... guess i gotta get ready to take it to service 6 times then hire a lawyer, ****nuts
Old Sep 22, 2011 | 08:12 AM
TSI_Shinobi's Avatar
DID anyone get a resolution to this?
ugakirk's Avatar
Yours is probably low on brake fluid. There is a sensor that regulates how much fluid is in the resivour. When you go to WOT, the sensor is probably tricked by the "sloshing" fluid..
Old Sep 22, 2011 | 08:53 AM
scarryy's Avatar
Yeah, I've had that. As your pads wear down you need to top off the brake fluid a touch. It doesn't have to be very low to trigger the slosh effect, like maybe at the bottom of the line on the res. Add a little splash and see what happens...
Old Sep 22, 2011 | 11:22 AM
TheBlade's Avatar
+1 I've had the brake and abs lights come on due to "sloshing" low fluid levels that when the car is at rest is above the minimum fill point on a 93 Escort GT, 05 Scion tC, and once on my 05 STi. It happens, and happens when pads wear a bit allowing the fluid to fill the calipers a little more
Old Sep 22, 2011 | 11:24 AM
jeffo24's Avatar
I topped off the brake fluid during lunch, it worked fine and the light doesnt come on anymore. makes sense that it was sloshing.
My question is, (forgive me if i'm taking over the thread) WHY was my brake fluid low at 4500 miles?? do the pads normally wear down enough at 4500 miles for this to occur? or do i have a leak?
Old Sep 22, 2011 | 08:32 PM
linkbeat's Avatar
Yeah, update please. Inquiring minds want to know (especially a Coloradoan)
Old Sep 22, 2011 | 10:00 PM
BMWTech's Avatar
Ya I would contact a lawyer about lemon law, that's BS that the dealer is returning the car to you unfixed. How far up the corporate mitsu tree have you barked? Have you taken it to multiple dealers? Mitsu dealer level of service isn't very consistent, if it's an option try another location. The smell is normal, it's not clutch but something like a body protection spray burning it off. I notice it several days a week after my 20+ mile commute to work. I'm over 10k miles now and I notice it less. Should go away with mileage/time. Best of luck, I hope it all works out.
