Sponsored by:
Sponsored by: CARiD
My new SST
Old Aug 20, 2011 | 10:57 AM
Loz114's Avatar
Question My new SST
I'm getting a new evo x SST fq300 in 2wks, having never driven a car with paddle shift and no foot clutch, is there any advice u can give me I.e hill starts, modes etc etc every thing will b useful cause this is my first Mitsubishi, I'm currently driving focus ST
Old Aug 20, 2011 | 11:12 AM
Type17's Avatar
The guy at my dealership told me to keep it in normal mode for the 1st few hundred miles to break it in. Other than that, not really much to point out. In normal mode it really emulates a run of the mill auto in the sense that its really straight forward.
Oh and I was reading the manual and it said that if you're idling for a while (more than you would at a stop light...) you should put it in neutral as opposed to leaving it in drive. Also, the car has a tendency to lurch forward when you lift your foot off the break. Manual says that using that to move around at low speeds for extended periods will head your SST up.
If you're driving it and you hear it whine (especially in 1st gear) don't worry because its normal. I lost a night of sleep over the whine the 1st day I bought the car thinking the transfer case is going to crap out on me but apparently the gearbox and transfer case are just loud in general.
Old Aug 20, 2011 | 11:32 AM
Loz114's Avatar
So u have settings for the transmission (normal, sport and s sport) and u also have settings for the paddles?? When u say manual your referring to using the paddles? I'm just worried when I pick it up from the uk and drive it back to Germany, when I'm driving on the ferry and have to stop on it's ramp with traffic that I shoot forward. Haha, that won't b good if I go into the back of some one
Old Aug 20, 2011 | 11:34 AM
lakay888's Avatar
Break it in first, dont launch it hard,you can do spirited driving once in a while during breakin, save up already for fluid/ filter replacement post breakin, i did mine at 10k,you can do manual or auto on all 3 modes depending on driving conditions, sport/s-sport is a blast to drive just make sure u have enough road, if ur lazy just set it on auto all u have to do is brk/gas point and shoot,i miss the heel/toe action sometimes, if u daily drive the car its nice that u dont have to deal with a clutch in rush hour, good luck
Old Aug 20, 2011 | 12:50 PM
Type17's Avatar
Hahah. When I said manual I meant the car's Owner's Manual. The transmission has only 3 settings, the ones you mentioned. If you want to use the paddles or the shifter to change gears yourself all you have to do is move the shifter into the D position, then push it to the left. From there you can shift using either the stick (pull towards you is shift up, push away from you is shift down) or you can use the paddles (right paddle shifts up, left paddle shifts down).
As for the car lurching forward, if you take your foot of the brake the car will start to roll forward even though you're not using the throttle (like in a regular automatic). Mitsubishi says that if you do this for extended periods of time the transmission may heat up, so they recommend that if you're sitting still for long periods of time just put it in neutral and back into D whenever you need to move. I'm certain you won't have any issues but its just something to keep in mind if there's really heavy traffic and you're not moving for long periods of time.
The only other settings you control is the S-AWC settings where you get to pick your driving surface (Tarmac, Gravel, Snow). In tarmac more power is sent to the rear wheels, in gravel it's pretty even, and snow mode is FWD biased. S-AWC is just a button between the cup holders and the shifter and you press it to toggle through the settings.
lowkey
Mitsubishi TC-SST Discussion
30
Oct 30, 2023 07:22 PM
Batsy
Jun 1, 2017 10:26 PM
Valerie Strong
23
May 17, 2017 12:02 PM
razorlab
32
Aug 17, 2011 10:30 PM
hccyong
Feb 14, 2010 10:53 AM
